Rear trim panel in vert - Mustang Evolution
Old 03-24-2012, 09:11 AM   #1
WillysYJ's Avatar
Has anyone replaced the speakers in the rear side panels of the convertible? I have searched YouTube and the net and haven't found anything on the removal of it. I plan on replacing the rear sealers this afternoon so if anyone has any info let me know, if not, I'll be making a walkthrough of my own. Thanks for reading!
WillysYJ is offline   Reply With Quote
Old 03-24-2012, 10:13 AM   #2
GTRob504's Avatar
I have opened those panel to install my convertible light bar. The top panel that kind of looks like an arm rest, pull that forward and it pops off. Then you can just gently pull the side panel off by puling it inward. Looks for some instructions on how to install a light bar for photos.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 03-24-2012, 10:23 AM   #3
Mr. SoloDolo's Avatar
Yeah it's really easy just a few snap out parts. First it's alot easier to remove if the top is down then just gently pull up on the top cover that hides the hydraulic pump arms, then once that's removed pull the side panel slowly straight towards the front of the car you'll have to slide the seatbelts out of the way. once that's off you'll have access to the speaker housing unscrew the four screws with a torx 30 I believe and you will have to cut the tabs on the side off the speaker housing when you put you're new speakers in. (they get in the way!) And watch all the wires on the passenger side you don't want to cut the wrong one! Also when putting the side panels back in it's easier if the top is up! Hope this helps good luck!
Mr. SoloDolo is offline   Reply With Quote
Old 03-24-2012, 11:13 AM   #4
WillysYJ's Avatar
Thanks everyone! I'll be doing trying it in a few hours!
Trade in 2010 for a new 2012 Teboidro 2011-2014 Mustang GT 31 03-28-2012 08:49 AM
My drilled n slotted rotors came in! Venomouz831 Pre-2005 V6 Mustang 27 03-27-2012 11:55 AM
Rear end Surffer227 Pre-2005 V6 Mustang 20 03-25-2012 02:28 AM
17s in front 18s out back Bosaliniee 1996-2004 Mustang GT 17 03-24-2012 09:35 PM
Let's play guess what's in the box.. 5pointOh 2011-2014 Mustang GT 21 03-23-2012 07:31 PM
02:08 PM
