Pulleys problems - Mustang Evolution
Old 03-25-2012, 09:41 PM   #1
yankeegt07's Avatar
Pulleys problems
So if I change my under drive pulleys do I have to Change my belt so I won't have any problems ?????? Help me fast
yankeegt07 is offline   Reply With Quote
Old 03-25-2012, 10:43 PM   #2
What problems at u experiencing that force u to change your pulley?
If the belts good. Then why Change it?
Crunch9876 is offline   Reply With Quote
Old 03-25-2012, 10:46 PM   #3
yankeegt07's Avatar
I Change them to steeds pulleys under drive but is ****in up
Old 03-25-2012, 11:27 PM   #4
Aggiesrok's Avatar
What is screwed up? The belt is loose or you have electrical problems?
Old 03-26-2012, 09:02 AM   #5
frank07stanggt's Avatar
Shouldn't have to change the belt. Are you sure you put it back on correctly?
frank07stanggt is offline   Reply With Quote
Old 03-26-2012, 10:44 AM   #6
Re: Pulleys problems
generally a smaller or larger pulley change requires a belt when the tensioner cant compensate for it. I know I have always had to run a smaller belt when messing with pulleys.
Old 03-26-2012, 12:52 PM   #7
yankeegt07's Avatar
Oh ok yea that's what I herd a smaller belt just wanted to make sure thanks
Old 03-26-2012, 02:36 PM   #8
Dude this you put on as mallet larger or same size pulley?
Old 03-26-2012, 03:30 PM   #9
I did steeds under drives and I had no problem with the belt.
---------- Post added at 05:30 PM ---------- Previous post was at 05:28 PM ----------
I think In the steeda kit the harmonic balancer is smaller but the water pump is bigger so that should compensate for the pulley change. Maybe there is something wrong with your tensioner.
Make Ford recall these problems!!! ...800-392-3673 Lalayla 2005-2010 Mustang GT 62 12-11-2013 07:59 AM
Radiator Fan problems SCenteno112 Pre-2005 V6 Mustang 2 03-23-2012 06:54 AM
My arch nemesis... Drive-ability problems :( Otlaw80 1979-1995 Mustang GT 17 03-22-2012 06:47 PM
door problems sick5point0 1979-1995 Mustang GT 1 03-22-2012 03:18 PM
C&l sample tubes problems 04machazblue 1979-1995 Mustang GT 6 03-18-2012 10:41 PM
10:46 AM
