Largest rear tire - Mustang Evolution
Old 03-26-2012, 07:46 AM   #1
GunMetalBullet's Avatar
Largest rear tire
What is the largest rear tire someone is running without problems?
GunMetalBullet is offline   Reply With Quote
Old 03-26-2012, 09:15 AM   #2
BaSohol's Avatar
On what rim size
2007 Ford Mustang GT 5spd
Old 03-26-2012, 09:24 AM   #3
On a 20x10 deep dish. Also whats the largest pn the front on a 2x8.5
Old 03-26-2012, 08:05 PM   #4
S281's Avatar
Re: Largest rear tire
I know a couple guys that have got 315's back there with an adjustable panhard bar, 305's without.
S281 is offline   Reply With Quote
Old 03-26-2012, 08:57 PM   #5
offset has much to do with this
Old 03-26-2012, 09:04 PM   #6
What type of offset are we talking about? And what exactly is offset?
Old 03-26-2012, 09:10 PM   #7
offset is how far the wheel's mounting point is off the centerline of the rim itself.
think of it this way. The more offset the further from the rim slides outwards toward the fender. You want this so that with the tire its close but not past the fender so the tire doesnt hit the fender.
Thats the most you can go and this will give you the biggest rear tire. I dont know that limit on the newer cars so cant tell ya.
for example on my car 3.75 inches from the rotor if you were to measure directly outwards that would be the limit where you want the rim lip to come out to so when you have the tire which should be a bit past that it wonthit the fender edge when the tire goes up towards the fender.
I have 10" wide rims in the rear with a 4.00 inch front spacing and a 6.00 back spacing so 6 inches of my rim are behind the rotor mounting surface and 4 inches are in front of it... as you can tell I am past my limit and had to roll my fenders
the newer stangs have rolled fenders from the factory so you can push a bit more... but that number I dont know.
read this http://www.mustangevolution.com/must...and-tires-faq/
here is a pic off offset explanation
Old 03-27-2012, 05:10 PM   #8
Thanks a lot man!!
Cutting rear springs FastEddie03GT 1996-2004 Mustang GT 7 03-27-2012 11:06 AM
Tire size GunMetalBullet 2005-2010 Mustang GT 4 03-26-2012 02:31 PM
7.5 to 8.8 rear end Kflynn318 Pre-2005 V6 Mustang 3 03-25-2012 06:25 PM
Rear end Surffer227 Pre-2005 V6 Mustang 20 03-25-2012 03:28 AM
Rear end gears jwhayne0001 1979-1995 Mustang GT 18 03-24-2012 11:57 PM
04:51 AM
