Caster Camber Plates or Camber Bolts - Mustang Evolution
Old 03-30-2012, 04:33 PM   #1
OutlawGT's Avatar
iv lowerd my stang with eibach pro kit springs (1.5" drop) i was told to get CC plates or camber bolts which one would be better
OutlawGT is offline   Reply With Quote
Old 03-30-2012, 10:53 PM   #2
Terminator's Avatar
I lowered mine 2in i used caster camber plates in Jan. alignment is still lookin good
Terminator is offline   Reply With Quote
Old 03-30-2012, 11:11 PM   #3
OutlawGT's Avatar
Do you know which brand is better on the S197 cars?
Old 03-31-2012, 01:16 AM   #4
Terminator's Avatar
Well for mine I got j&m cause I heard from friends that they were pretty decent so far it's keepin up with my daily drives. You might want to do some research on your own just to see how it handles on our cars diff types.
Old 03-31-2012, 01:25 AM   #5
OutlawGT's Avatar
Iv heard great things about J&M and good things about max motorsports and iv heard the bad what year is yours?
Old 03-31-2012, 03:04 AM   #6
Terminator's Avatar
Mines a 2005
Old 03-31-2012, 04:03 AM   #7
Silversky545's Avatar
I have k springs and I picked up the bolts...I nicknamed my alignment "can't get right" I'd go w c&c if u can afford it....
Silversky545 is offline   Reply With Quote
Old 03-31-2012, 06:57 AM   #8
OutlawGT's Avatar
That's what I needed to know thanks man cc plates is the way I'm going to go then!
Old 03-31-2012, 08:10 AM   #9
GTRob504's Avatar
Well except for the fact that you will have to remove the springs all over again in the front, the J&M plates are the best most affordable option.
Take it to get it aligned as your toe in will also need to be adjusted.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 04-01-2012, 01:28 AM   #10
OutlawGT's Avatar
Rob What's your opinion on the maximum motor sports caster camber plates?
Old 04-01-2012, 09:26 AM   #11
GTRob504's Avatar
The MM caster camber plates are a bit more expensive and also provide a caster adjustment as well as camber. Since I have a 4 bolt strut tower brace, the MM,s would not have worked for me.
Old 04-02-2012, 12:32 PM   #12
Zaks06GT's Avatar
I have the eibach sportlines and I have the camber bolts and aligned great and holding on now for 6 months
Zaks06GT is offline   Reply With Quote
Old 04-02-2012, 02:25 PM   #13
Re: Caster Camber Plates or Camber Bolts
seems newer 05+ stangs sometimes they dont require anything to align it
Old 04-02-2012, 08:36 PM   #14
GTRob504's Avatar
That cause Ford tweaked the tolerances. For instance they say that anywhere between 0 and -1.4 degrees of camber is within range.
Old 04-03-2012, 02:28 AM   #15
OutlawGT's Avatar
I have a 4 bolt also and what exactly is caster? I know what camber is
Old 04-03-2012, 04:41 AM   #16
SLDGT500's Avatar
I too lowered mine and when it was aligned they mentioned that it was within tolerance.. It had the slight lean in look that most European cars use to come with in the 90's. In fact I believe to help the Challenger corner it too has a slight lean. But the bottom line was for moderate driving i was told there would be no issue. My Shelby is a DD and I average about 1000k a month (that is no typo or iPad auto correct) and at the 17k mark they were smoked. The tire was worn down one the outside 2/3rds.. And the insides looked new. So when I had some other work done I had the C&C plates installed. Since then I have put 13k on the new tires and they look great. So IMHO invest in the plates and pay once not twice.
SLDGT500 is offline   Reply With Quote
Old 04-03-2012, 07:32 AM   #17
GTRob504's Avatar
The best way I know how to explain caster is , the measure of change of the vertical angle of the tire when turning versus straight line.
http://www.tirerack.com/tires/tirete...e.jsp?techid=4
Old 04-04-2012, 02:30 AM   #18
OutlawGT's Avatar
Which caster camber plates did you use?
---------- Post added at 02:30 AM ---------- Previous post was at 02:30 AM ----------
Ok thanks! Learn something everyday!!
Old 04-05-2012, 05:55 PM   #19
SLDGT500's Avatar
The shop I used outside of Philly ordered them from American Muscle. I am not sure. They are just down the road from them.
Tires exp with potenza re-11 or firestone oval indy 500? Yellow50 2011-2014 Mustang GT 25 04-12-2012 03:59 AM
Mac longtubes or pacesetters? Venomouz831 Pre-2005 V6 Mustang 42 04-04-2012 06:32 PM
Turbo/s or supercharger? Xofferick 2011-2014 Mustang GT 11 04-02-2012 01:49 AM
Retro-styled Black plates for californiA Jayjay General Mustang Discussion 4 03-30-2012 01:44 PM
New headlights or rims? Mustang 4pt0 2005-2010 Mustang GT 38 03-29-2012 09:41 PM
10:06 PM
