loss of power! - Mustang Evolution
Old 04-03-2012, 06:53 PM   #1
Mr. SoloDolo's Avatar
loss of power!
For some reason my pony has recently seemed to have lost power!
I have new royal purple oil in it, new transmission fluid and screen, new cooling fluid, new air filter, I clean my sparks every 3-6 months and I'm about to change the fuel filter. Any thoughts on what's causing the loss of power?
Mr. SoloDolo is offline   Reply With Quote
Old 04-03-2012, 10:00 PM   #2
tc x 4's Avatar
Have you tried cleaning the maf sensor.
Old 04-03-2012, 11:46 PM   #3
No I haven't but last time I looked at it it was as shiny as a new nickle lmao! I'll try tomorrow though but do I just wipe it clean?
Old 04-03-2012, 11:50 PM   #4
tc x 4's Avatar
Electrical contact cleaner.
Old 04-04-2012, 08:04 AM   #5
sinister07's Avatar
Re: loss of power!
As mentioned before, try cleaning the MAF sensor. Be sure to use spray cleaner that is labeled MAF cleaner, however. How many miles on the car?
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 04-04-2012, 03:16 PM   #6
Ok i will get some and do it today my car currently has 81,000 miles on it
Old 04-04-2012, 10:49 PM   #7
sinister07's Avatar
Re: loss of power!
If you had over 100k on the car, I would have suggested getting the 02 sensors looked at.
2003 Mach 1
Old 04-04-2012, 11:06 PM   #8
tc x 4's Avatar
Do you know if the rears will work in the front ?
Old 04-04-2012, 11:09 PM   #9
Aggiesrok's Avatar
No engine light at all?
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 04-05-2012, 02:16 AM   #10
No there is no CEL but something to consider is the weather here in New Orleans has been crazy and there has been a few flash floods lately i don't know if water got into the engine bay.
Old 04-05-2012, 07:35 AM   #11
Aggiesrok's Avatar
Does it run fine in neutral? Can you rev through to 5500 rpm? Or is it weak always? What year? Auto or 5 speed?
Old 04-05-2012, 11:54 PM   #12
Ok so i noticed that its loss of power is really noticeable when i really get on it and press the gas it seems like it takes a while to get up and go
Old 04-06-2012, 12:46 AM   #13
Aggiesrok's Avatar
Did you put the same weight oil in when you used royal purple?
Old 04-06-2012, 05:47 AM   #14
tc x 4's Avatar
Fuel filter ?
Old 04-06-2012, 02:48 PM   #15
Yeah same weight 5w30
And yeah i think im gonna try the fuel filter also
Old 04-06-2012, 09:18 PM   #16
Aggiesrok's Avatar
If its not the fuel filter, you may have a bad coil pack. I replaced several on my old expedition.
Old 04-07-2012, 10:43 PM   #17
RedGT's Avatar
Run a fuel system cleaner through after you do the filter. You could have dirty injectors.
RedGT is offline   Reply With Quote
Old 04-12-2012, 10:37 AM   #18
Ok so I changes the filter ran a cleaner through and there's a little difference it just seems that when I'm driving and want to gain speed I push the gas and it seems like it takes a while before the engine revs and changes gears?!!
Old 04-12-2012, 10:52 AM   #19
RedGT's Avatar
Do you have a manual or auto transmission? If its auto you could have a lack of fluid. Something else to look into is the throttle body. Try running some cleaner through it. If its gummed up then you won't get a good throttle response.
Old 04-12-2012, 12:37 PM   #20
I have an auto and I just had my transmission flushed and the filter changed about 2 1/2 weeks ago at Ford. I'm still gonna try the throttle cleaner though! Thanks
Old 04-12-2012, 03:50 PM   #21
RedGT's Avatar
The other thing could be a lack of power to the TB. Corrosion in the wires or something like that.
Old 04-12-2012, 08:13 PM   #22
Aggiesrok's Avatar
When in park do you get good throttle response? Can you floor it and it's normal?
Post up some pics of your 96-04 Mustang! FORDGT14 Pictures and Videos 4665 11-29-2017 11:55 AM
get rid of body kit or?? Sonicblue03gt 1996-2004 Mustang GT 29 04-07-2012 09:51 AM
Ford Racing Power Pack 08Mustang 2005-2010 V6 Mustang 17 04-04-2012 12:38 PM
post clips of your exhaust sound 1quick4.6 Pictures and Videos 37 04-02-2012 11:34 PM
02:11 AM
