Question regarding PCM flashing - Mustang Evolution
Old 01-02-2008, 09:45 AM   #1
05bluestang's Avatar
This may sound stupid, but...........................
I installed a C&L "racer" CIA over the Holidays and flashed the PCM with an 87 oct costum program from Evolution Performance. The power gain, according to the seat-o-pants meter, was impressive. Now I would like to flash it with 91oct tune. Do I have to reload the OEM program befor re-flahsing with the 91 oct. program?
Thanks
Helmut
2005 Mustang GT, Pacesetter LT's with OR H-pipe, "Magna Pack" exhaust, Techco SC @ 9psi making 464whp & 449tq, steeda tri-ax shifter, 3D Carbon Eleanor Grill, Pioneer F90BT, FRPP 3.73 gears.
Get in, sit down, strap in, hold on, shut up!
05bluestang is offline   Reply With Quote
Old 01-02-2008, 12:36 PM   #2
rocknbronco's Avatar
Re: Question regarding PCM flashing
Most programers will require a return to stock format before stepping it up a level, I would plug in the programer and see what it says.
rocknbronco is offline   Reply With Quote
Old 01-02-2008, 02:52 PM   #3
hottcobra's Avatar
with an SCT II you don't have to. just program and 91 octane
Old 01-02-2008, 03:16 PM   #4
What type of programmer do you have?
Old 01-02-2008, 04:17 PM   #5
Y2E0L0L5OGWT's Avatar
^Xcal 3 if his sig is accurate
Old 01-02-2008, 07:00 PM   #6
I have the SCT X3. Yes my sig is accurate.
I had it up on the lift for an oil change (royal purple) over the holidays and discovered that the previous owner not only installed the magnaflow cat-back but also installed an X-pipe (I yhink it's Pypes but could not swear to it)
Old 01-04-2008, 01:00 PM   #7
Got my answer from Evolution performance last night. With the X3 programmer you have to restore the factory program before loading another one.
Old 01-26-2008, 06:54 PM   #8
You mind as well skip right ahead to the 93 octane tune...
jwhite is offline   Reply With Quote
Old 01-27-2008, 09:23 AM   #9
I tried the the 87 fist, ran pretty good (vast improvement over stock). Now I am running the 91 tune. Performance is pretty impressive but seems to be in two steps (above 3500rpm is get like an extra umph). I did not buy the 93 tune but have the "91 extreme" but did not load it yet...........................
Over Drive light keeps flashing? BlackBullet Mustang Audio & Video 4 03-11-2010 03:38 PM
i have a question yoast88 1996-2004 Mustang GT 4 12-29-2008 07:02 AM
98' V6, 3.8 AUTO PCM PART#??? alexx_302 Pre-2005 V6 Mustang 0 01-23-2006 03:27 PM
PCM question...car's not starting! Oxygenetic Pre-2005 V6 Mustang 2 12-12-2005 05:30 PM
Getting my PCM out Brent Pre-2005 V6 Mustang 5 07-07-2004 09:10 AM
03:20 PM
