Drivetrain messed up???? - Mustang Evolution
Old 04-18-2012, 10:02 AM   #1
BaSohol's Avatar
I was leaving the gym, driving normal btw and I got to the light to turn on a main road, and while wait at the light I heard a sort of loud metal clunk and I think one more as I was driving, then I get to the next light and hear this, I thought it was a jackhammer at the nearby construction site, but nope, the noise goes away when the clutch is pressed in and I believe it makes the noise regardless of being in gear or not. I guess do you think its the clutch or transmission? I kind of hope its the trans cause at least that's under warranty and secondly what should I put back to stick before I bring it to the dealer
Here's the video with the noise
2007 Ford Mustang GT 5spd
Old 04-18-2012, 11:17 AM   #2
Silversky545's Avatar
From what I hear it sounds like the motor is clunking.... And the dealer will throw a fit because u have new gears... 4:10s and slicks r rough on stock tranys and rear ends... And they know why u put 4:10s in (if they find out u have them) and they will also be able to tell u have or had a custom tune... Might be a problem
Sux, I'll post your video on a local mustang club site to see if anyone will know that sound
Silversky545 is offline   Reply With Quote
Old 04-18-2012, 11:27 AM   #3
BaSohol's Avatar
If it was the motor why would it go away when I press in the clutch? And how would the dealer know I have 410s? They won't check that, I called my mechanic he said he doubts its the throw out bearing and says could be something internal in the trans
Old 04-18-2012, 12:06 PM   #4
MavyMav's Avatar
If it goes away with the clutch in it may be something with pressure plate or flywheel? I figured I would give you options. Im no expert on trannys. There is a TSB for rattling from something in the tranny.
MavyMav is offline   Reply With Quote
Old 04-18-2012, 12:09 PM   #5
It just sounded like it was motor... Hard to tell from that video ... How does the car preform ?
Old 04-18-2012, 12:10 PM   #6
MavyMav's Avatar
Do you feel anything in the shifter or the pedal? And what about when you are driving?
Old 04-18-2012, 12:21 PM   #7
BaSohol's Avatar
Ok thanks for the help, I drove it some more and it doesn't make the noise in second while engine braking, but as soon as you give it gas, like very little just enough to take the load off the trans it starts again
---------- Post added at 01:21 PM ---------- Previous post was at 01:11 PM ----------
I'm going to check the exhaust too, but if it is the throw out bearing, what clutch should I get cause I'll replace that while the trans is out
Old 04-18-2012, 12:23 PM   #8
Gibby's Avatar
+1
Gibby is offline   Reply With Quote
Old 04-18-2012, 12:30 PM   #9
MavyMav's Avatar
It does not sound like a bad TOB. It would not be that loud. At least when mine was bad it did not sound that clunky. It sounded more like a slightly cracked open window on the freeway. That sound you have is very loud and very clunky. Sounds like something is loose within the clutch engagement system. When you engage the clutch the sound goes away like something is holding it still. Hence why I said pressure plate or flywheel.
Old 04-18-2012, 12:40 PM   #10
BaSohol's Avatar
Heres some more news, if it's in gear and I'm at parking lot speeds letting it engine brake it doesn't make the sound and then when I give it slight gas to take the load of the trans it makes the noise again
Old 04-18-2012, 02:30 PM   #11
BaSohol's Avatar
Also I have yet to take the car to the track to launch with the drag radials
Old 04-18-2012, 02:53 PM   #12
tc x 4's Avatar
I can't hear the noise on my phone. Try jacking car up an turn wheels , possibly a chipped tooth on a gear. If so u might b able to feel it, but I'm thinking trans or like other guy said pressure plate.
Old 04-18-2012, 03:27 PM   #13
BaSohol's Avatar
I'm think it might me the trans as well cause like In said before I was siting at a light and I felt a clunk like I shifted a gear ( the noise it makes when the cars off and you just shift thru the gears
Old 04-18-2012, 03:41 PM   #14
tc x 4's Avatar
I know u have a warranty, but for sum reason they won't fix it. Get a Ford manual and do it your self. Manual trans are really not that complicated if u can follow simple directions . Good luck bud, guess I'll have to wait to see what that bad boys gonna run this yr with the drs .
Old 04-18-2012, 03:45 PM   #15
BaSohol's Avatar
I have extended extra care plan as well, if they say anything I'll say the parts where on the car when I bought it and the dealer should of disclosed that with me haha
Old 04-18-2012, 03:53 PM   #16
tc x 4's Avatar
Exactly what I'd say. My dealer never disclosed the mods on my car to me.
Old 04-18-2012, 03:57 PM   #17
BaSohol's Avatar
Gooosh I have 410s??? What's those??? Is that why I get bad gas mileage? Does that add horse power???? Hahaha
Old 04-18-2012, 04:58 PM   #18
S197Miller's Avatar
haha! I'd love to see the expression on their faces if you ever say that!
S197Miller is offline   Reply With Quote
Old 04-18-2012, 05:23 PM   #19
BaSohol's Avatar
I got referred to a cool ford service writer who is good friend with one of my friends so I don't think I'll have to do that
Old 04-19-2012, 02:19 PM   #20
MavyMav's Avatar
Got any updates on your situation?
Old 04-19-2012, 05:12 PM   #21
BaSohol's Avatar
Sorry I've been busy, working 12 hour shifts at work, but if they don't replace the throw out bearing under warranty, I guess I'll just upgrade my whole drivetrain
Old 04-20-2012, 08:36 AM   #22
BaSohol's Avatar
Dealer today, a tech drove it and convinced its something bad in the transmission it self, so they are going to drop the trans, good thing I got the extended warranty. But we will see if its really the trans in a bit
---------- Post added at 09:36 AM ---------- Previous post was at 09:35 AM ----------
Also what's a good clutch, I'm going to replace it if they drop the trans…. I'm think Ram HDX stage 2 and I'll just resurface the flywheel
Old 04-20-2012, 11:12 AM   #23
Zaks06GT's Avatar
McLeod is a great clutch
Zaks06GT is offline   Reply With Quote
Old 04-20-2012, 11:25 AM   #24
BaSohol's Avatar
Where can I buy it? And get shipped overnight
Old 04-20-2012, 12:22 PM   #25
Zaks06GT's Avatar
Late model restoration or American muscle
Or cj ponyparts
Old 04-20-2012, 02:49 PM   #26
BaSohol's Avatar
Ohh I didn't see it, I only saw exedy ram and spec at AM I'll check again
Old 04-21-2012, 07:47 PM   #27
BaSohol's Avatar
Update.......
Trans is out, they will rebuild it Monday, mean while I bought a CenterForce dual friction clutch to replace my factory one, I've only heard good things about CenterForce from friends and online, you look up Spec and every other post is something bad, plus I didn't have to wait for shipping since I live in Joliet which is a big race car area we have speed shops every where and I was able to walk in a purchase it right then and there which is always a plus instead of FedEx busting your balls
Old 04-21-2012, 07:51 PM   #28
Aggiesrok's Avatar
Update.......
So what was the answer on the tranny?
Old 04-21-2012, 08:10 PM   #29
BaSohol's Avatar
Something came loose or broke, they won't know for sure till Monday when they open up the trans, it's already on the bench, out of the car, so I assume if it was something simple like a throw out bearing or pilot bearing they would of seen it by now
Old 04-23-2012, 08:58 AM   #30
BaSohol's Avatar
Update trans is toast
Old 04-23-2012, 09:48 AM   #31
The Blue Dragon
GrabberBlue5.0's Avatar
What is that a pic of?
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 04-23-2012, 09:57 AM   #32
BaSohol's Avatar
Well a pic of worthless metal, but it was 1-2 gear something haha I don't remember I didn't really ask to much
Old 04-23-2012, 10:28 AM   #33
The Blue Dragon
Hmm, wonder what's wrong with it... Besides the fact that it's not in the tranny lol. Just asking questions because I love learning
---------- Post added at 12:28 PM ---------- Previous post was at 12:28 PM ----------
About cars haha
Old 04-23-2012, 10:35 AM   #34
BaSohol's Avatar
It chipped some teeth and traveled thru the whole gearset and chew up everything
Old 04-23-2012, 10:37 AM   #35
The Blue Dragon
O dang!!
09:09 PM
