Alignment problems!!!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Closed Thread
Old 04-24-2012, 08:09 PM   #1
Gibby's Avatar
Gibby is unknown around these parts
So I lowered my car about five months ago. I used the eibach anti-roll kit, the eibach pro kit with tokico d-spec shocks and struts and caster camber plates. I went to have it aligned and told the service writer and the tech what I had. I just realized my front tires are wearing on the inside of the tire.
Gibby is offline
Old 04-25-2012, 07:10 AM   #2
Borii is unknown around these parts
Send a message via AIM to Borii
Re: Alignment problems!!!!
I would assume, after a certain height, the camber can only be adjusted be so much since it squats. I would think that you can still adjust it enough to reduce, not completely eliminate, uneven wear some more.
SOLD - 06 GT 371WHP/332WTQ
Coming Soon - GT500
Borii is offline
Old 04-25-2012, 07:39 AM   #3
Gibby's Avatar
Yea I was just thinking that I got it aligned right after I lowered it, now that the springs have settled I'll have to take it back : /. But with the caster/camber plates it's supposed to zero out.
Gibby is offline
Old 04-26-2012, 06:45 PM   #4
GTRob504's Avatar
GTRob504 is unknown around these parts
What caster camber plates do you have?
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline
Old 04-26-2012, 06:53 PM   #5
Gibby's Avatar
J&M
Gibby is offline
Old 04-26-2012, 07:41 PM   #6
GTRob504's Avatar
I have the same and my struts don't poke up nearly as high as yours. Those plate have a widE range of adjustment.
GTRob504 is offline
Old 04-26-2012, 07:54 PM   #7
Gibby's Avatar
Stick up that high? I think you meant to put that on the other thread.... I know they have alot of adjustment just finding someone in my area that is able to do it is the problem
Gibby is offline
Old 04-26-2012, 08:56 PM   #8
Watchawow07SGT's Avatar
Watchawow07SGT is unknown around these parts
Wut size tire u running? I know wen I got my new wheels the guy at discount tire told me not to go wot the 245/35/18 I wanted. Instead he recommended me a 255/40/18 tire in the front. Told me that if I did go wit wut I wanted to weight of the engine would cause the tire to wear on the inside. So I went wit wut he said.
Watchawow07SGT is offline
Old 04-26-2012, 10:39 PM   #9
Gibby's Avatar
I have a 255-35-20. I think it's the lack of ability and comprehension of English between me and the "tech" that did it the first time.
Gibby is offline
Old 04-26-2012, 10:57 PM   #10
bullitt1075's Avatar
bullitt1075 is unknown around these parts
Send a message via Skype™ to bullitt1075
When they aligned your car did they give you a print out? There is a possibility your springs settled more since the alignment and you gained some excessive negative camber. Most shops guarantee their work for 6 months and will fix it for free.
Proud owner of Bullitt #1075
bullitt1075 is offline
Old 04-26-2012, 11:31 PM   #11
Gibby's Avatar
Yea that's what I figured, that my springs settled. As long as I have the car I get free alignments. I'm goin tomorrow.
Gibby is offline
Old 04-27-2012, 06:26 AM   #12
Labrat's Avatar
Labrat is unknown around these parts
Did you install a bump steer kit?.....I had my stang lowered and the alignment is dead on.
Labrat is offline
Closed Thread
12:45 PM
