04-26-2012, 07:56 PM
#1 | | Registered User
| Hood lifting at speed
My 2008 GT did not have that problem untill a replacement hood was installed after collision damage. At 75mph on I-95 I hit a 20mph + head wind and driver side middle lifted 2"  . I pulled off to check for obvious unlatch but could find no problems. At next gas stop after continuing to watch the hood lift I found an issue. The inner and outer panels of the hood are not bonded, welded, or crimped tight enough (steel hoods are spot welded don't how these aluminum hoods are done, anybody know?  ) so they slide on each other and do not offer support to each other as they should. With hood open front corners easily rack 6" or more up and down. Its like two seperate loose panels not one structual unit. Now to get Progressive to replace it is the task  >
04-26-2012, 08:44 PM
#2 | | Registered User
I have OEM hood, no wrecks, and my hood has popped up on me on the high way twice... The hook caught it both times but still... I think it's a defect from factory
04-26-2012, 09:09 PM
#3 | | Blogger
| Re: Hood lifting at speed
Are you sure it is shut all the way? Sometimes you have to close it twice before the hood latches.
__________________ |
04-26-2012, 09:14 PM
#4 | | Registered User
Hood pins? Would these help this?
04-26-2012, 09:23 PM
#5 | | Blogger
| Re: Hood lifting at speed Quote:
04-26-2012, 11:08 PM
#6 | | Registered User
I have a carbon fiber hood an it flexed a ton at highway speed so I got hood pins and it fine now.
04-26-2012, 11:11 PM
#7 | | Registered User
| Quote: |
Originally Posted by Solomo2 Hood pins? Would these help this? | +1
04-26-2012, 11:36 PM
#8 | | Registered User
Yes my hood was latched... :-/ hood pins will fix the problem that's sorta what they are for lol... But I refuse to use hood pins on a stock hood seems silly
04-27-2012, 12:56 AM
#9 | | Do The Evolution
| Quote: |
Originally Posted by Silversky545 Yes my hood was latched... :-/ hood pins will fix the problem that's sorta what they are for lol... But I refuse to use hood pins on a stock hood seems silly | Not silly, it's Gangsta! Gangsta.
04-27-2012, 02:49 AM
#10 | | Registered User
| Quote: |
Originally Posted by Silversky545 Yes my hood was latched... :-/ hood pins will fix the problem that's sorta what they are for lol... But I refuse to use hood pins on a stock hood seems silly | The Shelby GTs look nice with the hood pins
2007 Ford Mustang GT 5spd
04-27-2012, 01:28 PM
#11 | | Terminator Owner
a friend had their hood split between the bottom layer and the top and it flew up and smacked the windshield.... yea thats not good at all.
__________________ 2003 Cobra Vert (Redfire) #3938 of 5082 @ 05/27/2003
472rwhp/493rwtq - Modification List - Dyno Sheet 2012 Mustang 3.7L M6 (Kona Blue) 2011 Ford Edge Sport (Red Metallic) |
04-27-2012, 05:53 PM
#12 | | Registered User
Well if peoples stock hoods are blowing off the car apparently the hood pins serve a function
04-27-2012, 06:53 PM
#13 | | Registered User
I love how they look on my hood. And if they serve a purpose than even better. It is a stock hood that has been cut and had a new scoop fiberglassed into it.
04-27-2012, 08:31 PM
#14 | | Registered User
Hood pins look good on any mustang and the reason the hoods fly open is because the mustang hood doesn't have any venting for the air to exit the engine bay
I need them on my car because my ram air hood really lifts up when driving on the highway just saying
04-27-2012, 08:52 PM
#15 | | Registered User
| Quote: |
Originally Posted by BaSohol I must be, cause I dont see why hood pins look good on the Shelby but won't on the gt
I'm lost and stupid  | Whose Shelby is that? It looks great!!
04-27-2012, 09:02 PM
#16 | | Registered User
| Quote: |
Whose Shelby is that? It looks great!! | Idk I agree tho,
Going to make my car look like a Shelby GT but with matte black strips and black billit grill and black hood pins
04-27-2012, 09:12 PM
#17 | | Registered User
From other forums I have heard of outer hood seperating and crashing windshield and a recall on earlier mustangs for hood seperation problems. I am trying to find out if the only thing that holds the OEM aluminum hoods together is the fold on the edge. I have seen steel hoods spot welded and folded on the edge and some with glue or sealer on middle bracing. I don't have access to my original hood to compare with what I have now from collision repair.
04-27-2012, 10:47 PM
#18 | | Do The Evolution
| Quote: |
Originally Posted by tc x 4 Somebody needs to get laid. | Ugh, is it that obvious? I haven't had poon in weeks.
But seriously. I've got hood pins on my ram air hood. I added them because I was having lift issues and the flush mount kit I installed did the trick and look awesome at the same time. If I still had my stock hood, I'd put hood pins on that too if it was doing the same thing. I'd rather spend $50 on a set of pins rather then over a grand replacing the hood and windshield.
04-27-2012, 11:21 PM
#19 | | Registered User
| Quote: |
Ya I was just busting his balls, it's nice | Thanks man. I'm not against anything here. I'm just saying if you need pins, get them. They are definitely worth it. Save your aftermarket hood!!!
04-27-2012, 11:39 PM
#20 | | Registered User
| Quote: |
Originally Posted by NightMare07
Thanks man I'm glad someone appreciates quality here. Sorry I actually spend some money on my hood BaHosol. But if you're jealous then that's your problem. Please please please go buy an aftermarket hood and tell me if you need hood pins with a CARBON FIBER hood. Sorry I need them and was giving advice from experience. |
I told my friend (who IMO has the baddest 05-09 in my area) to paint his hood like yours
04-27-2012, 11:42 PM
#21 | | Registered User
| Quote: |
Dude WTF is your problem? I never said anything about not having pins or not! I like the pins, and I don't want an aftermarket hood btw. Spend some money on some go fast parts chump, god damn your starting stuff outta nothing, read all my post and so me where I said hood pins were a bad idea | Once all mods are complete (for what u want) cf hoods w ram air do help "go fast" w weight reduction and forced air... To cool the motor and possibly allow for more air to b forced into intake... In my friends case, into his stage 3 roush twin screw... :-/ I want his car!!
04-27-2012, 11:56 PM
#22 | | Registered User
Just throwing this out there... I have a GT.. And my hood doesn't look like those at all...
04-28-2012, 12:08 AM
#23 | | Registered User
I do like your car BaSohol. I just want everyone to know sometimes good pins are necessary. No arguments, I want no arguments, I have likes for all mustangs. Just do whatever you need to to keep your hood/stang safe.
I need as much help on these forums as everyone else on occasion. I would like to have the help without bias when needed. Thanks guys sorry for screwing up the thread.
04-28-2012, 05:18 AM
#24 | | Do The Evolution
Man... This thread got derailed big time. IMHO as long as your hood pins are functional, run with that ****!
I came across this fake ass BS and I was like, WTF!!! http://www.americanmuscle.com/chrome-hoodpin-0512.html
It's laughable. I hope nobody on here bought that BS. Shame on AM for selling junk like this.
04-28-2012, 05:50 AM
#25 | | Moderator Emeritus
Let's please stay on topic guys.
That's unimpressive
04-28-2012, 07:46 AM
#26 | | Registered User
| Quote: |
Originally Posted by primer2tone Man... This thread got derailed big time. IMHO as long as your hood pins are functional, run with that ****!
It's laughable. I hope nobody on here bought that BS. Shame on AM for selling junk like this. | Those don't even look real...
04-28-2012, 12:03 PM
#27 | | Registered User
| Quote: |
I was following this thread, didn't see anything u or Chicago did. Not reading back again, but the other guy was a dic | Haha thanks man, the mod took em all off now. But things just jumped out of hand and the thread got off topic. Sorry again though guys.
04-28-2012, 12:10 PM
#28 | | Registered User
| Quote: |
Haha thanks man, the mod took em all off now. But things just jumped out of hand and the thread got off topic. Sorry again though guys. | It's all good, I have bad hair days too.
