Nitrous. - Mustang Evolution
Old 05-03-2012, 02:12 PM   #1
MustangCaracas's Avatar
Nitrous.
Hello guys!
This time i wanna ask you about using nitro!
My car has installed:
Steeda CAI
Sct tuner
4.10 gear
Tri-ax short shifter
BBK lt headers and o/rx
127200 Comp Cam Stage 2 camshafts.
My next move is to install nitrous kit from ZEX.
With bottler header, gauge, and purge kit.
Is it safe?
How should i use it with my mods?
MustangCaracas is offline   Reply With Quote
Old 05-03-2012, 02:15 PM   #2
Scott1984's Avatar
Are you wanting wet or dry? Also what size of a shot are you wanting?
Scott1984 is offline   Reply With Quote
Old 05-03-2012, 02:22 PM   #3
Wet
I don't understand that stuff! Hahaha I'm from venezuela and i'm not used to the meanings of shots in nitrous
Old 05-03-2012, 02:29 PM   #4
Rapinator126's Avatar
spray the **** out of it lol. everyone has gotten a bad feeling of nitrous bc of the dam movies. i had it on my roush as well as my bike and going on my new 5.0. just get a good dyno tune do not trust email tunes for nitrous.
---------- Post added at 02:29 PM ---------- Previous post was at 02:24 PM ----------
shot refers to the size of jet. 75hp. 100hp 150hp 175hp. all refer to the shot
Old 05-03-2012, 02:37 PM   #5
Ok, but at track when may i use it? From how many rpm or gear?
Old 05-03-2012, 02:39 PM   #6
i had mine set up to start spraying in 3rd gear at 100% throttle.
Old 05-03-2012, 02:42 PM   #7
Scott1984's Avatar
That depends. If I would use it it would be in 4th or fifth gear. I don't know if I would ever use it on the track though unless you have a real long straight away.
Old 05-03-2012, 02:44 PM   #8
to start spraying in 5th gear would be pointless pretty much. 3rd is fine trust me
Old 05-03-2012, 02:47 PM   #9
Scott1984's Avatar
---------- Post added at 02:47 PM ---------- Previous post was at 02:46 PM ----------
[/COLOR]Also did u set your car up for six speed or is it a five speed? Nm I re-read and saw your gears
Old 05-03-2012, 02:48 PM   #10
Forum Car Trader
90GTNovi2000's Avatar
Really we always sprayed the nitrous when the light turns green until we lift.. Talk with a local tuner though you can have a switch added so you can flip it and have the pill available at WOT.. But it requires a tune to ****** the timing for best performance..
90GTNovi2000 is offline   Reply With Quote
Old 05-03-2012, 02:49 PM   #11
i had 410s supercharger and it was a 5 speed. started in third at full throttle with a 100shot. there would seriously be no point to spray in 5th good way to blow your motor.
---------- Post added at 02:49 PM ---------- Previous post was at 02:48 PM ----------
this was all with my 08 roush.
Old 05-03-2012, 02:50 PM   #12
Scott1984's Avatar
Yeah you do have a point there.
Old 05-03-2012, 02:51 PM   #13
What does 100 shot means? The quantity of NItrous?
Old 05-03-2012, 02:51 PM   #14
if he uses it at the track. he could spray off the line but will need a good set of tires and suspension to put it to the ground.
Old 05-03-2012, 02:52 PM   #15
Scott1984's Avatar
Sorry to take the post away but did u do that to your 1200 hp fox too? That had to be a hell of a ride!
Old 05-03-2012, 02:57 PM   #16
yes 100 shot is 100hp. but will show a little more usually on a dyno.
---------- Post added at 02:53 PM ---------- Previous post was at 02:52 PM ----------
the 1200 hp fox is just procharged 30psi. no nitrous lol. it is already has trouble hooking up.
---------- Post added at 02:57 PM ---------- Previous post was at 02:53 PM ----------
the fox is a 434 with 30psi through a f1r procharger.
Old 05-03-2012, 03:09 PM   #17
Forum Car Trader
Nice sounds fun.. I'm gonna build a 408 soon for mine..
Old 05-03-2012, 03:11 PM   #18
spraying it?
Old 05-03-2012, 03:22 PM   #19
Forum Car Trader
No for my fox I have a Paxton novi2000
Old 05-03-2012, 10:21 PM   #20
frank07stanggt's Avatar
i have a zex wet kit with a 100shot. i start spraying in second at 2700rpm and stop at 5700. second seems to work pretty good for me cause i usually have pretty good traction by then. also i use a window switch so it sprays all by itself. it is awesome. i kept up with a s/c stang with it.
frank07stanggt is offline   Reply With Quote
nitrous
01:34 AM
