Ram Air project - Mustang Evolution
Old 05-06-2012, 09:52 AM   #1
BaSohol's Avatar
Ram Air project
Well step one was to get a light, however I got it for real cheap and it's new, so imma feel bad hacking it up
My idea is to cut the lens out, and a 4" hole in the back, along with duct work to ensure proper flow,
Now I was just going to put a funnel where the chrome reflector is, but a member throw me the challenge of making it functional headlight too
Challenge accepted
So I'm order some mountable projector with color shifting holos to mount in front of the funnel and to hide the mounting Of the projector I will install stainless Steel wire mesh
Well just sharing my idea, feel free to ask questions or give me ideas, I start tomorrow on it
Also it's a quick sketch to give you an idea, I want it to have sort of a terminator look
ID:	49329   Click image for larger version
2007 Ford Mustang GT 5spd
Old 05-06-2012, 12:22 PM   #2
S281's Avatar
Re: Ram Air project
Good idea, but isn't that going to mess with the effectiveness of the headlight if you remove some of the reflector. Dont you need to protect the bulb some how? Just a thought.
S281 is offline   Reply With Quote
Old 05-06-2012, 12:27 PM   #3
BaSohol's Avatar
Yes that's why I'm removing the stock bulb and installing this
Old 05-06-2012, 12:34 PM   #4
S281's Avatar
Re: Ram Air project
Ok got it. Should work then. Good luck with it.
Old 05-06-2012, 07:51 PM   #5
tc x 4's Avatar
I know it will work if you can get enough fuel in there also. Not a fan of the halos tho, but a challenge is a challenge.
Old 05-06-2012, 08:07 PM   #6
Lorraine's driver
ab_mach1's Avatar
Challenge accepted
Don't forget some way to drain some water out of your lowest area on the way to your filter. Could be a disaster should you get splashed from another car going over a chuck hole. I went through a touchless car was to wash the salt from the road off my car and I freaked out halfway through thinking water would get through from the shaker. When I popped the hood and inspected things I noticed there is a drain at the bottom of the shaker and everything slopes to the drain. It scared the hot biscuits out of me! Probably want something for the setup you make.
Instagram: @ab_mach1
Old 05-06-2012, 08:14 PM   #7
BaSohol's Avatar
I already have a way to keep water out, I'll use my removable blackouts, takes 5sec to put on
Old 05-06-2012, 08:20 PM   #8
Lorraine's driver
ab_mach1's Avatar
Cool, good idea and looks sweet too! I like the red around your grill. Nice touch!
Old 05-06-2012, 11:38 PM   #9
Silversky545's Avatar
His GTi mod?
Silversky545 is offline   Reply With Quote
Old 05-06-2012, 11:49 PM   #10
Lorraine's driver
ab_mach1's Avatar
Originally Posted by Silversky545
His GTi mod?
Like the idea he has with the ram air and the headlight covers to protect from rain Also like the red pin strip around the front grill from his most up a thread or two. Not a big fan of the projector head lights. But it seems like that's the direction of automakers these days.
Old 05-07-2012, 07:51 AM   #11
BaSohol's Avatar
I'm not sold on the projector part, silversky just told me to make it functional, since I proved it could be done I'll make it with out the light first
---------- Post added at 08:51 AM ---------- Previous post was at 08:49 AM ----------
His GTi mod?
Ya my GTI mod, and since I'm the first to do it, that I know of, we are calling it the BASohol mod now
Old 05-07-2012, 12:35 PM   #12
Or BASgti mod
Old 05-07-2012, 12:39 PM   #13
BAS make sure you take lots of notes and try to do this as cheap as possible because I read more about agent47 ram air kit and it makes massive speed improvements after 40mph... And I have a feeling if u pull this off in a very clean fresh from the factory look, you will have buyers lined up (96-13 mustangs) so keep all the how to install notes to your self... Get your self paid! unless you don't care to make it a part time job lol then tell all
Old 05-07-2012, 02:12 PM   #14
Aggiesrok's Avatar
Re: Ram Air project
Just getting cooler air should make a big difference. Hope you don't get a lean code.
Old 05-07-2012, 02:15 PM   #15
Lorraine's driver
ab_mach1's Avatar
Is there when you would/could need stronger fuel pump and/or larger injectors?
Old 05-07-2012, 02:20 PM   #16
Aggiesrok's Avatar
Re: Ram Air project
I don't know if you would increase air flow enough for larger injectors, but it may need to be adjusted with a tune.
Old 05-07-2012, 03:06 PM   #17
BaSohol's Avatar
The car should make the adjustment itself thru the MAF
Old 05-07-2012, 04:34 PM   #18
Aggiesrok's Avatar
Re: Ram Air project
My CAI connection to the TB got loose and created a small gap, allowing a more air in. This cause it to run horrible and threw a CEL code. But now that I think about it, that would have been beyond the MAF, SO nevermind.
Old 05-09-2012, 05:13 PM   #19
spookshow's Avatar
I have a cervinis functional ram air hood and intake. Works Awsome. Looks great too! Your idea is kinda like a old Chevy concept of air intaked around the light. Nice.
spookshow is offline   Reply With Quote
Old 05-09-2012, 05:26 PM   #20
Lorraine's driver
ab_mach1's Avatar
Does your setup work with a specific type or size of filter? Wondering if your get to take advantage of the newer types of high flow filters, like K&N.
Old 05-09-2012, 05:44 PM   #21
spookshow's Avatar
It's a kit that cuts away 1/3 of the orginal box. Uses stock or as i use K&Ns. No adjustment to settings. No tune needed. Runs great. Better gas mpg too. If u keep ur foot out of it. Really picks up and breathes right when u hit 40 mph. I like ur idea I wanna make intake for front air brake cool off the tuck in the blinkers up to the fender seem. Like the 70s.
Old 05-12-2012, 05:54 PM   #22
BaSohol's Avatar
Update!!!!!!!! Cut up the lenses and edged it
ID:	50286   Click image for larger version
ID:	50289   Click image for larger version
Old 05-13-2012, 12:15 AM   #23
spookshow's Avatar
I want to remove the whole cover, is the bulb protected inside or not? Yours looks clean. Good job!!
Old 05-13-2012, 09:19 AM   #24
BaSohol's Avatar
No the bulb is not protected and of I took all the plastic off the black out cover wouldnt fit on it anymore
Old 05-13-2012, 06:46 PM   #25
RedGT's Avatar
I'm sure you could get a plastic of some sort to cover the inner reflector and protect the bulb.
RedGT is offline   Reply With Quote
12:21 PM
