Clutch replacement - Mustang Evolution
Old 05-17-2012, 05:00 PM   #1
Bennyhill's Avatar
Clutch replacement
Hey everyone just need some advice regarding my clutch. I'm upgrading to an 8 bolt flywheel + new clutch. Both spec clutches and flywheel.. I would like to upgrade my through out bearing and slave cylinder. Will an oem set up work? Or is there something better that will work with my set? I read on American muscle the "ram" brand will not work with my spec clutch. Is there another aftermarket set that will work?
Bennyhill is offline   Reply With Quote
Old 05-17-2012, 09:17 PM   #2
Gil_T2's Avatar
Re: Clutch replacement
is your current clutch bad? if not leave it alone. I know guys running low 11's on stock clutch. also you can not upgrade to an 8 bolt flywheel, and the OEM slave/tb's are the best,
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 05-18-2012, 05:41 AM   #3
Bennyhill's Avatar
Well I am upgrading my whole engine. With a stroker kit that requires a 8 bolt flywheel. And my clutch I upgraded prior to the rebuild but it wasn't working properly. It wasn't fully disengaging IMO. I would push in the clutch but It wouldn't drop into gear until the rpm's dropped.
Old 05-18-2012, 07:08 AM   #4
BaSohol's Avatar
Which brand was that?
2007 Ford Mustang GT 5spd
Old 05-18-2012, 09:35 AM   #5
Bennyhill's Avatar
Both are spec clutch and flywheel stock tranny and eagle crank
02:02 PM
