New shaker 1000 head unit - Mustang Evolution
Old 05-19-2012, 06:02 PM   #1
Was wondering if anyone knew if a new 2012 shaker 1000 head unit will fit into the place of the unit in my 2006 gt or if it is even compatible. also does the new unit have satellite radio and an aux jack? Any help would be appreciated.
The Third is offline   Reply With Quote
Old 05-21-2012, 11:38 AM   #2
Gil_T2's Avatar
Re: New shaker 1000 head unit
NO, will not work,
Sat is not built in to the radio, it is mounted in the trunk, on the right side behind the trim panel. The wiring should be there if you have a shaker 500 radio. The radio is a CAN BUS radio, if you install the Sat receiver in the trunk, the radio will see it and install it ( like a computer does).
Aux jack should be mounted in the console it is part of the wiring harness.
You can not install the shaker 1000 unless you do a lot of wiring.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 05-21-2012, 02:25 PM   #3
Sorry i should have given better details. I currently have the shaker 1000 in my car that came stock. However I'd like an aux jack and satellite radio but I don't like the look of aftermarket head units. So I'd like to put a newer shaker 1000 head unit in the place of mine. Obviously some modification for satellite radio hook ups would be needed but other than that would this scenario be possible?
Old 05-21-2012, 02:41 PM   #4
Gil_T2's Avatar
Everything i posted still applies, There should be a connector behind your trunk mounted Amps to plug the Sat receiver into. If you don,t have an auto jack in your console go here for easy plug in adapters for your radio.
Pac-Audio.com Product Search | iPod Integration for your car and More by Pac-Audio - Connecting you to the future
09:32 AM
