Need help on 2005 GT rear brake pads? - Mustang Evolution
Old 05-19-2012, 11:35 PM   #1
N8ive Mustang's Avatar
What tool is needed to compress piston??
N8ive Mustang is offline   Reply With Quote
Old 05-19-2012, 11:48 PM   #2
Eturner's Avatar
Don't recall it's name, but there is a special tool for that!.. If you have an AutoZone or other parts store that rents tools, just go there and ask them!.. They will know what your talking about!..
Old 05-20-2012, 03:05 AM   #3
tc x 4's Avatar
Use a c clamp
Old 05-20-2012, 06:27 AM   #4
RedGT's Avatar
Originally Posted by tc x 4
Use a c clamp
You need to rotate the piston as you push it in. It's a special design and a c clamp alone won't work. Some stores sell brake cubes that have various notches in them, but you'll probably want a complete disc brake kit. Comes with the piece to rotate the piston as well as the piece to compress it. Do some research on this one because its not like the front caliper.
RedGT is offline   Reply With Quote
Old 05-20-2012, 06:32 AM   #5
tc x 4's Avatar
Thanks, that's new to me.
Old 05-20-2012, 06:37 AM   #6
frank07stanggt's Avatar
I used a c clamp and a big pair of channel locks to turn it while the c clamp pushed it. But there is a tool for it.
frank07stanggt is offline   Reply With Quote
Old 05-20-2012, 08:32 AM   #7
Eturner's Avatar
Get the tool for it!.. It will be so much easier!..
Old 05-20-2012, 08:59 AM   #8
Untamed5.0's Avatar
Leave the old break pad in and use a really big pair I pliers and slowly compress the piston back into the caliper. Works like a charm.
---------- Post added at 09:59 AM ---------- Previous post was at 09:58 AM ----------
That was based on the face that it didn't need to be rotated. Whoops!
Untamed5.0 is offline   Reply With Quote
Old 05-20-2012, 10:57 AM   #9
Gil_T2's Avatar
Re: Need help on 2005 GT rear brake pads?
All calipers that have the E-brake built in need to be rotated , basicly screwed in. That go's for most E-brake calipers dating back to the late 70's. If you use a C-clamp you will break the caliper.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 05-20-2012, 01:25 PM   #10
Caster Troy's Avatar
Region: Hawaii
You need a special tool to compress the piston or you will damage the boot. I have one but I don't know the name. Sorry.
Caster Troy is offline   Reply With Quote
Old 05-20-2012, 01:41 PM   #11
Blogger
99ford's Avatar
Disc Brake Piston Tool AKA as a brake cube. Autozone will have have it.
Old 05-20-2012, 03:30 PM   #12
Always broke's Avatar
Goto Advance Auto rent their master brake tool set. It's basically free 100 bucks out front then you can return it for full refund.
---------- Post added at 03:30 PM ---------- Previous post was at 03:29 PM ----------
A piece of a vice forget about the cube but your knuckles up
Always broke is offline   Reply With Quote
Old 05-21-2012, 10:57 AM   #13
Send a message via AIM to Borii
Originally Posted by tc x 4 View Post
Use a c clamp
+1111111
They can NOT be pressed. You can do dual pliers rotation but I couldn't get it to budge. I bought the kit and it took seconds.
How far are you? I have the tools.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-22-2012, 04:30 PM   #14
sinister07's Avatar
This is the tool you need. Harbor Freight Tools has them for under 5 Bucks.
Lisle Corporation
2003 Mach 1
sinister07 is offline   Reply With Quote
Old 05-22-2012, 05:38 PM   #15
Lisle Corporation
I like that one as well for the $. I have the press one which is a lot easier but that tool is simple and cheap
Sold - 2001 Audi S4
Old 05-22-2012, 08:24 PM   #16
GTRob504's Avatar
The little cube thing won't work. Just go to a local auto zone. And tell them you want to borrow a brake repair tool kit. They have all of the right tools and it's free.
2008 Metallic Alloy GT Convertible Premium
Show : black top| 18" bullitt polished wheels| CDC light bar and black billet replacement grilles | black/amber corner lights | GT500 rear spoiler| AH chin spoiler Go: FRPP CAI with StangHi tunes | Kooks LT's | FR500 axle back | Steeda Sport springs | Koni STR.t struts/shocks | J&M camber plates | UMI adj. panhard bar | LCA relocation brackets | GT500 LCA's | Hurst Billet shifter | 3.73 gear | FRPP axle girdle | Baer Rotors and Pads
GTRob504 is offline   Reply With Quote
Old 05-22-2012, 08:24 PM   #17
tc x 4's Avatar
Lisle Corporation
Good info
Old 05-22-2012, 09:14 PM   #18
I've successfully used it. Pain in my ***.
Sold - 2001 Audi S4
Old 06-11-2012, 07:27 PM   #19
roxteddy's Avatar
long nose pliers?
roxteddy is offline   Reply With Quote
06:31 AM
