J&M LCA Review - Mustang Evolution
Old 05-20-2012, 12:34 PM   #1
BaSohol's Avatar
J&M LCA Review
Well I received them in the mail Friday and I order them Wednesday from AmericanMuscle. Upon opening the package I noticed everything was packaged nicely and it included instructions unlike my sequential tail lights so that was a plus.
The arms themselves were very nice looking, perfect finish, not one imperfection, the welds looked nice, not sanded down to cover up a bad weld job. The bushings looked good but that should be expected.
Install was easy! MAYBE an hour job, I did it but myself cause my buddy was working on his car, and I never had to call him over for help.
Test drive well that's was like night and day, it was quiet no squeaks whatsoever! And the feels more solid backing out of a drive way curb. Now the performance review, it HOOKS!!!!! Snaps your neck! I might not even need the drag radials! That's how good it feels
Spend what you want on the brand! Just buy LCAs
ID:	51157   Click image for larger version
ID:	51159   Click image for larger version
2007 Ford Mustang GT 5spd
Old 05-20-2012, 12:58 PM   #2
Loc: Austin,TX
Re: J&M LCA Review
Nice review,bout to do some myself.
Old 05-20-2012, 04:07 PM   #3
Aggiesrok's Avatar
Told Ya!
289 - Holley 4150 570cfm; Performer intake; mild cam; MSD HEI; 302 heads; Roller Tips; Hedman Tri-Y headers; H-pipe w/Flowmaster 40's; 9 in posi 3.50; 205/50-17F; 225/50-17R.
Old 05-20-2012, 05:25 PM   #4
BaSohol's Avatar
I believed you, just didn't know if it was something to spend a lot of money on or go the cheap route
Old 05-20-2012, 06:14 PM   #5
BCS06GT's Avatar
Unless your lowered, then you need relocation brackets, otherwise they don't do s***
BCS06GT is offline   Reply With Quote
Old 05-20-2012, 06:22 PM   #6
Aggiesrok's Avatar
That's got to be badass with your gears and new tranny. Enjoy.
Old 05-21-2012, 11:55 AM   #7
Send a message via AIM to Borii
Re: J&M LCA Review
The opposite. You ONLY NEED relocation brackets if you're lowered. BUT for them to work as far as forward traction, you;'re right. He needs reloc brackets.
Stock height cars get improved and immediately noticeable rear stability, less twist in the arm upon launch compared to the OEM design. The twisting will probably the only improvement over stock as far as straight line acceleration and THERE I agree that they do not do anything.
But they serve more use than just a froward traction piece.
Are you lowered? Otherwise the 'hooks' is placebo.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 05-21-2012, 12:52 PM   #8
BaSohol's Avatar
Your saying my car getting better traction is a placebo effect???? Really like I stupid enough not to know or feel a difference?
Old 05-21-2012, 12:56 PM   #9
Re: J&M LCA Review
If your car is not lowered, then the angle is the same. My Car has the same bars. If the angle is the same as stock there is NO gain in forward traction. There will however be a huge increase in forward stability because the bar is much thicker than the skinny flimsy stock arm that can shift a miniscule bit on forward acceleration. Also adds better cornering stability with a better ride over uneven surfaces.
Didn't say you were stupid. As I never would, but a fact is that not everything we 'feel' yields a real world result.
Sold - 2001 Audi S4
Old 05-21-2012, 01:42 PM   #10
Aggiesrok's Avatar
Re: J&M LCA Review
It's the combination of the flexing the stock LCA's and the stock rubber bushings that cause the wheel hop. It flexes and tries to straighten over and over at launch. The replacement LCA's are more rigid and they use a high durometer polyurethane bushing. The relocation brackets can improve the geometry and further lock the axle in place, and are necessary with lowered cars. But replacing LCA's definately nearly eliminates wheel hop.
Old 05-21-2012, 01:58 PM   #11
BaSohol's Avatar
Ive launched my car plenty of times and even brake stand burnouts, and I did all the same after the install, let's say the launch improvement is small which it's not, I can tell the difference from spinning and wheel hopping to just plan ol hooking and going, and I decided to do a brake stand burnout like I would at the track, this would cause horrible wheel hop before, to the point I thought the dash was going to break apart, now it was smoother with the LCAs
Old 05-21-2012, 02:51 PM   #12
Re: J&M LCA Review
I will admit that wheel hop is something I did not consider mainly because, for no reason that I can conjure, I have never had wheel hop. Stock or otherwise.
Sold - 2001 Audi S4
Old 05-21-2012, 03:29 PM   #13
tc x 4's Avatar
The wheel hop is from the stock bushings. I bought Ford racing lca's and they are the same as stock,except different paint and bushings. I had terrible wheel hop, now it hooks and goes . I don't think it pulls the wheels yet, but you can barely see over the hood. When I take it to the track and it don't hook , I'll buy the brackets because changing the geometry does make sense to me.
---------- Post added at 04:29 PM ---------- Previous post was at 04:27 PM ----------
Borri , I find it hard to believe you've never had wheel hop.
Old 05-21-2012, 04:29 PM   #14
Re: J&M LCA Review
So do I. I never experienced in THIS car. I attribute it to never driving it stock on good tires. I went from stock pirellis that were bald when I got them to My nittos and Spring install at the same time. I think the tires not having any grip what so every originally is what allowed me to skip on the hop. I also was launching very low until this weekend, so that also played a role most likely in my lack of wheel hop.
Sold - 2001 Audi S4
12:19 PM
