Exhaust that doesn't pop? - Mustang Evolution
Old 06-07-2012, 08:28 AM   #1
Hey guys, i'm new to the forum just have a quick question i hope. i've got a 07 GT, i want to put an aftermarket exhaust on it and have been combing the internet and youtube trying to find and exhaust that doesnt "pop" or sound like a backfire when you rev it or let off the throttle. not doing a full exhaust just mufflers. i think it does this due to the lower back pressure and it seems all the exhausts are 3" diameter or larger. I would appreciate any suggestions or remedies for this.
86GTFoxBody is offline   Reply With Quote
Old 06-07-2012, 08:38 AM   #2
351mustanggt's Avatar
does it have stock cats?
351mustanggt is offline   Reply With Quote
Old 06-07-2012, 09:09 AM   #3
Yes the car is completely stock. Just want a deeper tone
Old 06-07-2012, 06:44 PM   #4
2007pullinaway's Avatar
My friend has an 09 just about bone stock he just took off the mufflers and just ran straight pipe is really deep and aggresive
2007pullinaway is offline   Reply With Quote
Old 06-07-2012, 06:50 PM   #5
I already tried a pair of pypes muffler deletes and it popped bad. So I figured there would be a muffle set out there that didn't pop
Old 06-07-2012, 08:11 PM   #6
could it be running a little rich thats causing it to pop?
Old 06-08-2012, 07:32 AM   #7
I don't think so. Every 05-09 I hear with aftermarket exhaust does it. I didn't know if someone out there had a set on there car that didn't do it.
Old 06-08-2012, 08:16 AM   #8
Jake's Avatar
I have pypes muffler deletes and they dont pop?
Jake is offline   Reply With Quote
Old 06-08-2012, 09:39 AM   #9
When u let off the throttle you don't get like a poppy crackling sound. That's the best I can describe it.
---------- Post added at 09:24 AM ---------- Previous post was at 09:18 AM ----------
Go to this utube site and listen when he let's off the throttle
---------- Post added at 09:39 AM ---------- Previous post was at 09:24 AM ----------
This is exactly what I'm talking about.
Old 06-08-2012, 10:18 AM   #10
Jake's Avatar
Ill post a video on youtube hang on bro
Old 06-08-2012, 10:40 AM   #11
Gil_T2's Avatar
Re: Exhaust that doesn't pop?
All most any performance car will pop under the right conditions, and the way you drive the car. I bet you down shift to slow the car, that will always make it pop. So just get something you like, i run stock Ford Bullitt mufflers, and i can make it pop if i want.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 06-08-2012, 11:04 AM   #12
i guess Its just the nature of the exhaust system. And it's something I'll have to get used to
Old 06-08-2012, 11:09 AM   #13
Jake's Avatar
Old 06-08-2012, 11:50 AM   #14
Yeah yours does it also. Must just be the way the sound rolls out of the pipes. Sounds good though
Old 06-08-2012, 12:08 PM   #15
Jake's Avatar
Well its not horrible to a point i cant take it, it hardly does it mostly just when cold. Thanks
Old 06-13-2012, 06:02 PM   #16
LeviG2010's Avatar
Magnaflow 3" magnapack cat-back exhaust gave my car a deeper tone while keeping the popping to a minimum
The driver doesn't pick the car. The car picks the driver.
LeviG2010 is offline   Reply With Quote
Old 06-13-2012, 07:44 PM   #17
Thanks I'll check it out
Old 06-13-2012, 08:38 PM   #18
OneSick07's Avatar
So you wanna get rid of the famous mustang sound and have it sound like every other v8 car with flowmasters is that what your getting at
OneSick07 is offline   Reply With Quote
Old 06-13-2012, 08:43 PM   #19
Charles.young10's Avatar
JBA.. Deep sound.. No popping..
Charles.young10 is offline   Reply With Quote
Old 06-14-2012, 08:40 AM   #20
No I don't want to get rid of the nice sound just the popping. I think it sounds cheap sorta like some young kid with an old 350 chevy pickup who decided to cut the mufflers off.
---------- Post added at 08:40 AM ---------- Previous post was at 08:30 AM ----------
The JBA sounds really good
Old 06-14-2012, 08:49 AM   #21
OneSick07's Avatar
I don't have mufflers on mine but mine runs perfect and sounds awesome if you wanted I deep tone that doesn't sound good you shoulda bought a Chevy and called it quits
Old 06-14-2012, 10:20 AM   #22
garbill2003's Avatar
I don't think you are going to get rid of the pop to be honest
garbill2003 is offline   Reply With Quote
Old 06-14-2012, 12:05 PM   #23
I was checking out some clips of the JBA's and they sound pretty good I may go with them. And to "onesick07" I just don't wanna be that d-bag driving around with a stock car and an obnoxious exhaust.
Old 06-14-2012, 12:11 PM   #24
I love mine.. Not insane loud.. But very good deep tone..
Old 06-14-2012, 01:20 PM   #25
OneSick07's Avatar
Mines far from stock this is the 5th one I've had and they all sound the same. Unless you go with an over priced exhaust you WILL NOT get rid of the pop it's the exhaust tone they are known for!
Old 06-14-2012, 01:37 PM   #26
I'm not here to bulldog back and forth about what you have or had. This isn't my first either and there are obviously exhaust out here that don't other people have them.
---------- Post added at 01:35 PM ---------- Previous post was at 01:34 PM ----------
And the fact that yours is "far from stock" you probably have more than enough back pressure to flow 3"-4" pipes thus it probably does sound good
---------- Post added at 01:37 PM ---------- Previous post was at 01:35 PM ----------
Correction* your pushing enough pressure that the lack of back pressure doesn't effect the sound
Old 06-14-2012, 01:42 PM   #27
Region: Arkansas
I know I'm a bit late on the draw here, but I can explain the popping.
Long explanation:
They are lean-condition pops. When you let off the throttle, your motor experiences a low air/fuel ratio and causes the popping sound.
It is in no way harmful to your motor, in fact, it happens every time you shift in a stick. It's just part of the exhaust system.
The catalytic converters do wonders in suppressing the sound (listen to a catless GT rev and you'll notice it has wicked loud pops - ESPECIALLY if you have an x pipe). Longtube headers and a catted H is the only thing I've noticed to decrease in the popping.
Short explanation:
Exhaust just pops: every car I've owned pops. Corvettes, Mustangs, trucks, etc. It's the nature of the beast.
BackPressure is offline   Reply With Quote
Old 06-14-2012, 02:03 PM   #28
Long explanation:
Short explanation:
My 400ex honda pops to its something thats always going to be their I agree
Old 06-14-2012, 02:14 PM   #29
Yes anything built or with an aftermarket exhaust will pop. I was just wondering if any aftermarket exhaust manufactures remedied this. Your factory stock cars u can rev the hell out of and won't pop.
Old 06-14-2012, 02:27 PM   #30
Region: Arkansas
Longtubes. That's about it and they still pop some.
exhaust
01:34 PM
