Omg help! - Mustang Evolution
Old 06-07-2012, 09:59 AM   #1
SoCalKev's Avatar
Send a message via Skype™ to SoCalKev
Omg help!
So my 05 Gt has a big problem
My steering wheel moves from side to side like shake while driving
And I feel every bump on the road through my pedal.
Its really bugging me.
And no it doesn't need a alignment because the car does pull to either side just a huge shake.
Please help any input will help.
20 inch rims.
And I checked for cracks and yeah
SoCalKev is offline   Reply With Quote
Old 06-07-2012, 12:45 PM   #2
RedGT's Avatar
Could be a lot of things. Ball joints, tie rid ends, bearings, suspension, out of balance wheels, etc. I would recommend taking it to a mechanic as soon as you can.
---------- Post added at 12:45 PM ---------- Previous post was at 12:44 PM ----------
Tie rod*
RedGT is offline   Reply With Quote
Old 06-07-2012, 01:00 PM   #3
It's not me, it's you.
primer2tone's Avatar
Jack the front end up and see if you've got any play in the wheels. With your hands on the tire
positioned at 3 & 9 o'clock. Try to move the wheel from right to left. Then, positions your hands at 12 & 6 o'clock and try to move the wheel up and down. If the wheel has play left to right, you have a bad tie rod end. If you have play left to right and up and down, you've got a bad wheel bearing. If you only have play up and down, then you've got a bad ball joint.
If you've got no play. Take it to a tire shop and get you wheels balanced. And if you still feel the shanking in the wheel and pedal, then you have an unbalanced brake rotor and I'd recommend you replace the brake pads and rotors.
Old 06-08-2012, 01:57 PM   #4
Caster Troy's Avatar
Region: Hawaii
It's most likely a tire issue, either balance or a tire separation. If you feel it all the time no matter what speed you probably have a separated tire. Feel both your front tires for a bulge or bubble in the tread.
If it happens at around 55 60 MPH and smooths out as you speed up then it's your balance.
Hope this helps.
Caster Troy is offline   Reply With Quote
Old 06-08-2012, 01:59 PM   #5
SoCalKev's Avatar
Problem resolved!
Tire had a huge fuxking boil!
Check it
Old 06-08-2012, 02:04 PM   #6
Region: Hawaii
I knew it. What kind of shoes did you get?
Old 06-08-2012, 02:06 PM   #7
SoCalKev's Avatar
Undecided I'm still here
Old 06-08-2012, 02:11 PM   #8
The Blue Dragon
GrabberBlue5.0's Avatar
Watch those potholes bro! That's a big part of what causes impact braking and bubbles on the sidewall. Go for the BFG sport comp 2's or something. Yokohama nexen, sumitomos, kumho are all junk
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 06-08-2012, 02:31 PM   #9
SoCalKev's Avatar
Thing is I just bought my car and it had ddecenti D6000 I didnt hit any pothole
Old 06-08-2012, 02:37 PM   #10
Region: Hawaii
Go Bridgestone, best performance and tread life. If you got the money go with the RE970 AS, great performance and it's the only ultra high performance tire with a 40K warranty. If you want summer tires the RE760 is solid and a lot less money. Sorry for sounding like a commercial.
Aloha!
Old 06-08-2012, 02:41 PM   #11
SoCalKev's Avatar
Aloha!
No dude it's quite fine I think I'm going for the RE's
Old 06-08-2012, 02:47 PM   #12
Holy tire bubble batman!
2005 Redfire GT - Mac LT's/prochamber, Pypes mid muffler, FRPP hotrods, 4.10's, Steeda tri-ax, JLT CAI, Bama tuned, Nitto nt05's 333/327 dynojet A little go go juice too
Southern stang is offline   Reply With Quote
Old 06-08-2012, 07:50 PM   #13
garbill2003's Avatar
Originally Posted by SoCalKev
Problem resolved!
Check it
Your luckey that didn't blow on you that could have been very bad
garbill2003 is offline   Reply With Quote
Old 06-09-2012, 09:15 AM   #14
SoCalKev's Avatar
Old 06-09-2012, 09:59 AM   #15
Babystang's Avatar
Damnnnnnnnnnn
Babystang is offline   Reply With Quote
08:13 AM
