06-08-2012, 10:14 AM
#1 | | Registered User
| Performance mods on a DD
Hey everyone! I have a 2008 GT with K&N Typhoon CAI, and Flowmasters. Other than that, performance wise, it's stock. I want to do basic and easy mods to help prevent me from being burned by these Chevy and Dodge dillholes who think they are bad because they bought a car stock that's faster than me. I need ideas, but keep in mind I'm not lookin to build a 1000hp (lol) car - the obvious tuner is the first thing on my list, what do you all suggest next?
06-08-2012, 10:47 AM
#2 | | Registered User
| Re: Performance mods on a DD
thro away that K&N p.o.s. , get a JLT or C&L cia and a good Bama tune from AM, with tunes for life, rear gears and a good DOT drag radial. learn to launch from a dig. best place to start.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
06-08-2012, 11:32 AM
#3 | | Legacy Member
| Quote: |
Originally Posted by Gil_T2 thro away that K&N p.o.s. , get a JLT or C&L cia and a good Bama tune from AM, with tunes for life, rear gears and a good DOT drag radial. learn to launch from a dig. best place to start. | So you think there is enough power difference between those intakes? I doubt it
Mine: -03 SB Cobra vert- 2552 of 5082 Born 02/25/03
Our's: 90 7up vert - new project-07 DSG Focus -DD 335 |
06-08-2012, 11:44 AM
#4 | | Do The Evolution
Longtubes and an off road x pipe. It's harder to install vs CAI lol, but it's worth it. Plus you'll be able to update your tune, after you've gotten the tuner.
__________________ |
06-08-2012, 12:03 PM
#5 | | Registered User
| Re: Performance mods on a DD Quote:
Originally Posted by lowflyn So you think there is enough power difference between those intakes? I doubt it |
Most definitely, the K&N is a stock size MAF. If he is going to tune the car, it will be even better. JLT showed 10 to 12 rwhp gains on stock equipped cars. If for only the improved drive-ability it was worth it on my car. The Ford Bullitt CAI with 85mm MAF added 15 hp to the car.
06-08-2012, 12:43 PM
#6 | | Legacy Member
| Quote: |
Most definitely, the K&N is a stock size MAF. If he is going to tune the car, it will be even better. JLT showed 10 to 12 rwhp gains on stock equipped cars. If for only the improved drive-ability it was worth it on my car. The Ford Bullitt CAI with 85mm MAF added 15 hp to the car. | So what gains does the k&n give? I don't think it'll be that far off
06-08-2012, 01:16 PM
#7 | | Registered User
K&N's only advantage is the performance of the filter itself. Their own dyno test show a max hp gain of 10 hp at the top end. there is no HP gain in the lower rpm range. You are also limiting any advantage you gain with a tune. The stock throttle body has 2, 55mm inlets,total 110mm, why limited your MAF to the stock size of 70mm. With a 85 or 95 mm MAF you could see 30 HP from about 2000 rpm up.
06-08-2012, 01:19 PM
#8 | | Evolution's Finest
Originally Posted by Gil_T2 Most definitely, the K&N is a stock size MAF. If he is going to tune the car, it will be even better. JLT showed 10 to 12 rwhp gains on stock equipped cars. If for only the improved drive-ability it was worth it on my car. The Ford Bullitt CAI with 85mm MAF added 15 hp to the car. | Think about it this way though... When you dyno a car with different CAIs on you are in a standing spot with the hood open and a lot of the time a fan is blowing to the engine... I highly doubt you will have those conditions on the road, I really have to agree with Lowflyn in this case.
06-08-2012, 01:34 PM
#9 | | Registered User
Originally Posted by Soccerluvr4 Think about it this way though... When you dyno a car with different CAIs on you are in a standing spot with the hood open and a lot of the time a fan is blowing to the engine... I highly doubt you will have those conditions on the road, I really have to agree with Lowflyn in this case. | how would those conditions make any difference, you are still limited by the size of your MAF, and the fan in front is there to help with cooling not RAM air affect. Plus the conditions would be the same for both CAI's.
06-08-2012, 05:20 PM
#10 | | Registered User
Thank for the advice about the intake all! A lot to chew on there. For low end power (again, not a drag car) would you all suggest shortys or long tubes - actually exhaust system through and through what's the best setup? What type of hole to I get myself in by exploring new cams? Thnx again for the advice.
06-08-2012, 06:42 PM
#11 | | Registered User
To help off the launch, get 4.10 gears help a lot on acceleration but take away top end. For a programmer I would go with SCT with Bama tunes from American muscle. Great programmer & you get free tunes for life, can't go wrong with that!
06-08-2012, 07:19 PM
#12 | | Registered User
| Quote: |
Originally Posted by Franco09GT To help off the launch, get 4.10 gears help a lot on acceleration but take away top end. For a programmer I would go with SCT with Bama tunes from American muscle. Great programmer & you get free tunes for life, can't go wrong with that! | Funny you should said that cause I just burned a 08 mustang Gt with the same mods, just not 410s he got me off the line when we raced from a dig but he did the 3 honks and I spun bad so we went from a roll, he still did the 3 honks but this time traction wasn't an issue, I instantly put 3 car lengths on him and kept pulling away, gears don't take away from your top end, your car runs out of hp b4 gear
2007 Ford Mustang GT 5spd
