DD tune - Mustang Evolution
Old 06-11-2012, 10:45 AM   #1
Joel_L_H's Avatar
DD tune
What do you guys use for a daily driver tune? Anyone use 93 race tune
Joel_L_H is offline   Reply With Quote
Old 06-11-2012, 10:48 AM   #2
LeviG2010's Avatar
I'm using 91 octane tune on my daily driver. But only because where I'm at we don't have 93. If I could id go 93.
The driver doesn't pick the car. The car picks the driver.
LeviG2010 is offline   Reply With Quote
Old 06-11-2012, 10:50 AM   #3
Lorraine's driver
ab_mach1's Avatar
Probably okay, but checking anyway... If you tune w/91, can you use 93 octane? No 91 around where I always get gas.
Instagram: @ab_mach1
Old 06-11-2012, 10:56 AM   #4
LeviG2010's Avatar
It shouldnt be any different then tuning for 87 and putting 91 in. I had to tune my car to 87 one time (stuck out in the middle of nowhere on a road trip and it was the only gas around) So I ran a tank of 91 before retuning it to 91. But as I've never had 93 I could be wrong.
Old 06-11-2012, 12:14 PM   #5
Gil_T2's Avatar
Re: DD tune
I ran a 93 tune, most of the improvement was on top end, retuned to 91 race, no real difference. runs great on the street, good mileage, runs 12.7 on street tires. If you do tune for 91 it is a waste to use 93, running the 93 lets you run more advance. If you race alot i would get 100+ race fuel, and tune for race day only, that will make a difference worth the extra money.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 06-11-2012, 12:43 PM   #6
Lorraine's driver
ab_mach1's Avatar
I'm worried about occasional knocking on a 93 race tune. Have you had that? Sounds like the 91 tune isn't much diff than the 87 tune.
Old 06-11-2012, 01:22 PM   #7
Re: DD tune
if you can get bad gas in your area then 91 may give you a little wiggle room, but if you are not WOT and you get slightly bad gas just dont go WOT and you will probably be just fine.
its also about timing, cut it back from peak a bit for DD duty
Old 06-11-2012, 03:01 PM   #8
tc x 4's Avatar
Late model restoration told me it wouldn't matter if I was out somewhere and couldn't find 93. I haven't tried it tho.
Old 06-11-2012, 03:33 PM   #9
Gil_T2's Avatar
Re: DD tune
Never had knock, i do not let my fuel get much below 1/2 so if i get some bad gas it gets mixed. There is more difference between 87 and 91 tune, than a 91 to 93
Old 06-11-2012, 03:44 PM   #10
Lorraine's driver
ab_mach1's Avatar
That's good to know cause being a DD, I might stay clear of the 93 tune. I've been thinking about getting ECU tune switch (don't know the real name) so you can switch between 2 tunes easily. But then again, I always dump 93 octane in my car so there's that.
Old 06-11-2012, 03:54 PM   #11
MedicDave's Avatar
I have a 93 tune and mine is a DD I have no problems.
MedicDave is offline   Reply With Quote
Old 06-11-2012, 04:22 PM   #12
Lorraine's driver
ab_mach1's Avatar
Maybe I'm just overly worried about it. Can you hear detonation on the cars pretty easily?
Old 06-11-2012, 04:27 PM   #13
Artaz's Avatar
So is there really any noticeable difference between the 91 and 93 tune??
Artaz is offline   Reply With Quote
Old 06-11-2012, 04:41 PM   #14
Caster Troy's Avatar
Region: Hawaii
I have had the same issue with the 93 tune, not so much a knock but more like a ping especially when getting on the throttle between shifts, slight ping them it clears. I too don't have 93 where I live only 92. What worked for me was Lucas oil octane boost, it stops the problem but is pretty pricey when you have to buy a bottle on every fill up. I since have changed my tune to 91 race and haven't had any problems nor did I notice much of a decrease in performance.
Caster Troy is offline   Reply With Quote
Old 06-11-2012, 08:01 PM   #15
tc x 4's Avatar
I would say not, different parts of the country have one or the other.
Old 06-13-2012, 06:31 AM   #16
Joel_L_H's Avatar
So the 87 street tune wouldn't be much different the a 93 race tune?
Old 06-13-2012, 06:45 AM   #17
MedicDave's Avatar
I haven't noticed anything, maybe I'm one of the lucky ones lol, I'm hoping that I have no problems when they put my cams in and change the tune, but for now I'm problem free. I haven't had any other tune then the 93 so I'm not sure about the other ones.
Old 06-13-2012, 06:55 AM   #18
Lorraine's driver
ab_mach1's Avatar
Definitely post up when you complete your cam mod!
Old 06-13-2012, 07:04 AM   #19
MedicDave's Avatar
I will for sure, it will be a wile before I can put them in, I have spent way to much money in to short of time and I'm pretty sure the wife will try to murder me if I spend more lol.
Old 06-13-2012, 07:32 AM   #20
Lorraine's driver
ab_mach1's Avatar
Ha! I know how that is. My wife gets mad every time she see's me checking out americanmuscle.com. "what do you need now?!"
Old 06-13-2012, 07:59 AM   #21
Send a message via AIM to Borii
Re: DD tune
I use the 93R tune for daily driving. I have NEVER loaded the 91 or 87 tune I got from them lol. They recommend you not to run the R tunes daily since throttle response is touchy, especially on 4.10s BUT you get used to it. Nothing footwork can't solve.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 06-13-2012, 08:11 AM   #22
MedicDave's Avatar
I will say that my throttle is extremely sensitive with the R tune, it's like your ether on it or off, it just wants to go lol, but iv learned to control it a little better with careful foot work, I love it it just adds to the driving experience.
---------- Post added at 09:11 AM ---------- Previous post was at 09:08 AM ----------
Lol, my wife does the same thing when I'm looking on AM.com "O what are you getting now, that's enough" lol.
Old 06-13-2012, 08:24 AM   #23
Joel_L_H's Avatar
Would I be getting better gas with the 93r tune or 87 street
Old 06-13-2012, 08:39 AM   #24
Re: DD tune
The 87 Street I BELIEVE, at least from bama is purposely designed to achieve better MPG while still adding some power.
The 93R has KILLED my MPG but I don't care haha
---------- Post added at 10:39 AM ---------- Previous post was at 10:39 AM ----------
I love it. They even recommend leaving in second, which I don't do.
Sold - 2001 Audi S4
Old 06-13-2012, 09:51 AM   #25
Re: DD tune
I have a 93 tune but I dont trust the gas 100% so pulling it back a bit is better for me, but being N/A and having a knock sensor you are probably fine.
Old 06-13-2012, 10:03 AM   #26
Lorraine's driver
ab_mach1's Avatar
So the tunes do not circumvent the knock sensors?
Old 06-13-2012, 10:21 AM   #27
Re: DD tune
I get it only from a few places to reduce the chance of lower aki than advertised.
Sold - 2001 Audi S4
Old 06-20-2012, 11:43 PM   #28
S0cuety's Avatar
I use a 93R tune and I drive 75 miles a day highway.. Gas mileage dropped a bit but nothing serious. Just my 2 cents
S0cuety is offline   Reply With Quote
11:00 AM
