Exhaust setup - Mustang Evolution
Old 06-16-2012, 09:57 PM   #1
T_math_6's Avatar
Exhaust setup
Installed SLP high flow cats and x-pipe, also Pypes muffler delete axel backs. And already had JLT cold air. God it sounds mean! Couldn't have a better setup as far as sound then that!
T_math_6 is offline   Reply With Quote
Old 06-17-2012, 01:28 AM   #2
Silversky545's Avatar
You could... add mufflers... it will make your car sound "good" again... loud noise does not equate to sounding good...
Silversky545 is offline   Reply With Quote
Old 06-17-2012, 09:42 AM   #3
BaSohol's Avatar
Cats quiet a car enough, no mufflers with cats sound the best besides flowmaster and cams
2007 Ford Mustang GT 5spd
Old 06-17-2012, 10:38 AM   #4
T_math_6's Avatar
Its loud, and also sounds good.
Old 06-17-2012, 04:09 PM   #5
Jgill1992's Avatar
My flowmasters with offroad H sound PERFECT at low rpm but if I go WOT or try and pass on the interstate its REALLY buzzy. Sounds like a ricer is flooring if beside me.
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 06-17-2012, 06:11 PM   #6
BaSohol's Avatar
What kinda of flows? 40s or the garage ones that are made to bolt in like the ones sold on AM
Old 06-17-2012, 06:24 PM   #7
tc x 4's Avatar
Pleeez, I've never herd them on a mustang, but my truck sounds dam good at any rpm with them.
Old 06-17-2012, 07:06 PM   #8
Jgill1992's Avatar
They sounded good until I added the h-pipe. Not sure what's causing it.
Old 06-17-2012, 11:30 PM   #9
BaSohol's Avatar
Mine sounds great low Rpm and wot but sound alright around 3k under medium throttle
Old 06-18-2012, 12:34 AM   #10
Jgill1992's Avatar
It sounds buzzy like its vibrating and the pipe is touching mettle but I can't see it touching anything.
Old 06-18-2012, 07:16 AM   #11
BaSohol's Avatar
That's weird, check the hangers, I was voted the best sounding s197 around here haha
Old 06-18-2012, 08:58 PM   #12
I'll take the number one spot when I'm finished...
Old 06-19-2012, 06:55 AM   #13
T_math_6's Avatar
I think mine sounds pretty good
Old 06-19-2012, 07:13 AM   #14
Lorraine's driver
ab_mach1's Avatar
There has to be something resonating with your exhaust. Def shouldn't sound like a buzzing. Is there heat shields anywhere? Sometimes if you just bend them some, it will change the frequency that will make them buzz.
---------- Post added at 09:13 AM ---------- Previous post was at 09:09 AM ----------
I'd like to hear it if you have any video of your exhaust. I have the Flowmaster cat back that is essentially muffler delete. Which Flowmaster setup do you have?
Instagram: @ab_mach1
Old 06-19-2012, 07:19 AM   #15
Jgill1992's Avatar
Deffenatly sounds buzzy. Best way I can describe it is sounds like there's a loose penny inside the pipe but it's ONLY between 2,800 rpm and 3,300 than it goes away but ive looked over every centimeter on exhaust pipe and I can't find it any wear. The exhaust shop just said I was crazy and they wouldn't even look at it
Old 06-19-2012, 07:25 AM   #16
T_math_6's Avatar
I had flow Master American thunders that did the buzz thing at idle and at 2500-3000 rpm range as well. Does blowing baffles have anything to do with buzz?
Old 06-19-2012, 07:33 AM   #17
Lorraine's driver
ab_mach1's Avatar
That's what makes me think it's resonating something under the car. It hits that RPM and starts making something dance, then it will stop once it gets past that resonating point.
Will it do this if you rev it without moving? If so, it might be easier to try some stuff that could help you find out if it's inside or outside the system.
Old 06-19-2012, 08:30 AM   #18
Jgill1992's Avatar
Re: Exhaust setup
It does do it when I rev it I feel bad holding the engine at that high RPMs in neutral long enough to try and pinpoint it
Old 06-19-2012, 08:47 AM   #19
Lorraine's driver
ab_mach1's Avatar
Yeah I wouldn't hold it there either Can you hear just revving up to it quickly? Of so, see if you can find something that you can wedge between the muffler and the body/frame. Like insulation or a small block of wood. By wedge, I mean something that goes against your exhaust and frame enough to give it stability, not that will damage anything. You just want to give some stability to the exhaust to isolate what might be making this noise. Now you can repeat the rev to see if the buzz changes. You can move your wedge thingy to different locations once you have tried it.
Old 06-19-2012, 09:04 AM   #20
Jgill1992's Avatar
Re: Exhaust setup
Thanks I'll try that when I'm home In a little bit
Old 06-19-2012, 04:14 PM   #21
Jgill1992's Avatar
Dangit wife took the GT to the store lol. Now I gotta wait to check it out
Old 06-19-2012, 09:06 PM   #22
I've had 4 set ups all of em did what u are talking about.. I have not heard a 3v that does not do it tho... and I've been around a ton of them
Old 06-19-2012, 09:07 PM   #23
Lorraine's driver
ab_mach1's Avatar
So is it coming from the engine?
Old 06-19-2012, 10:00 PM   #24
Zaks06GT's Avatar
Idk why but I can't stand the sound of flowmasters!!
Zaks06GT is offline   Reply With Quote
Old 06-19-2012, 11:15 PM   #25
Lorraine's driver
ab_mach1's Avatar
What setup do you like best? I'm thinking about going to Borla stingers.
Old 06-19-2012, 11:31 PM   #26
Zaks06GT's Avatar
For full exhaust I like Kooks headers with catted x pipe and Corsa axle back, I also like the borla stingers
Old 06-20-2012, 12:06 AM   #27
I have longtubes... bassani off road x and stingers... still get a nasty rattle... I'm switching to an off road h due to x pipes on 3v sound horrible IMO... only 3v that don't rattle are running mid mufflers... I'll sell these borlas at some point and pick up some bullet style mufflers
Old 06-20-2012, 12:13 AM   #28
Zaks06GT's Avatar
U want to sell your x pipe?
Old 06-20-2012, 12:53 AM   #29
Lorraine's driver
ab_mach1's Avatar
I haven't heard of Corsa. I'll check those out.
Old 06-20-2012, 01:09 AM   #30
Yes... but I have not taken it off yet... need a lift I don't like being under a car on the ground... not a fan of tight places.... I have the off road h pipe already just need the lift
Old 06-20-2012, 01:15 AM   #31
Zaks06GT's Avatar
Ok well let me know when u wanna sell it, what brand is it?
---------- Post added at 02:15 AM ---------- Previous post was at 02:14 AM ----------
I think Corsa is one of the best out there, if not
The best, it also comes with a high price tag lol
Old 06-20-2012, 01:14 PM   #32
Joel_L_H's Avatar
I wish I knew what this rattle sound was because all I have right now is mac axlebacks and i have no rattle at any rpms they sound good
Joel_L_H is offline   Reply With Quote
Old 06-20-2012, 02:10 PM   #33
Originally Posted by Joel_L_H
I wish I knew what this rattle spy.d was because all I have right now is mac axlebacks and i have no rattle at any rpms they sound good
Most people I encounter do not hear it until it's pointed out to them... I've been to several muffler shops all of witch say they do not hear it... I'm starting to think it's the valve train echoing through the exhaust... all I know is it sounds down right horrible.... it is more noticeable when you have after market mid pipe... it was not as bad when I just had axle backs...
Old 06-21-2012, 11:00 PM   #34
Jgill1992's Avatar
I'm starting to think it may just be the sounds through the pipe on mine too. I've had it in 3 shops and nobody can fix it so I'm thinking maybe LT headers might help
Old 06-21-2012, 11:23 PM   #35
OneSick07's Avatar
I've got my x pipe further back than stock and muffler deletes and mine sounds completely different now
OneSick07 is offline   Reply With Quote
exhaust
08:37 AM
