I need help with brakes - Mustang Evolution
Old 02-14-2008, 04:55 AM   #1
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
It is about time to replace my brake pads so I ordered some nice Hawk Performance brake pads and I was able to replace the front ones fine but I can not fit the rear calipers back on either side for the life of me. Am I retarded or is there some little trick that I am missing? My car is on the lift until I can get it back together so any advice soon would be really helpful. Thanks.
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 02-14-2008, 07:34 AM   #2
Re: I need help with brakes
I am not sure if it is the same as 94-04 but there is a tool needed on those that you need to allow you to compress the rear caliper's piston to slide it back on. Sounds like you need that. You may can rent it at autozone or something. I think the fitting is square or something~
Old 02-14-2008, 07:37 AM   #3
I was wondering the same brandon, I'm not sure if the new calipers are the same. What you have to do (I've done it with a screwdriver before) is push in and turn the piston at the same time to get it to set back into the caliper. Once you do this you can reinstall the new brake pads and be done.
Old 02-15-2008, 11:15 AM   #4
05RedDevil's Avatar
Apparently, you do need a specialty tool to depress the piston in the rear calipers. I wish my damn Haynes manual had mentioned that. Sorry to waste your time
Some show. Some go.
Old 02-15-2008, 03:51 PM   #5
Be Careful!!! If you try to compress the caliper with out turning the piston YOU WILL BRAKE THE CALIPER!!! Then you will have to replace it.
Truth is Truth whether YOU believe it or not:)
www.bigdmustangs.com
mustero is offline   Reply With Quote
Old 02-15-2008, 03:58 PM   #6
We'll let it slide this time. How dare you not use common sense and think the rear pistons would need to be turned in instead of pushed in like most other cars out there.
I hate turning mine in...it never seems to want to go in easily as the tool keeps slipping off every time you shift pressure a little bit.
Old 02-19-2008, 02:59 PM   #7
05RedDevil's Avatar
Ok, so I have a new upcoming issue. I've recently ordered new charge motion plates as well as underdrive pulleys. I know that the harmonic balancer requires a special puller so any suggestions as to what brand/kind of tool to buy or should i just have this work done?
Some show. Some go.
Old 02-19-2008, 03:34 PM   #8
hendog4321's Avatar
Send a message via Yahoo to hendog4321
ATI, Fluidampr, COMP Cams, and Moroso all make easy to use harmonic balancer puller and installer tools. Just depends on your brand preference and how much you want to spend. They range from $25 to over $100.
hendog4321 is offline   Reply With Quote
Old 02-19-2008, 05:02 PM   #9
05RedDevil's Avatar
No brand prefence. Just want it to work. Price is, well, like anyone else, free is best but I'll pay what I need to so it gets done right. Thanks for the help
Some show. Some go.
BRAKES DMAC General Mustang Discussion 5 02-18-2008 08:26 PM
Brakes mongolchuck 1979-1995 Mustang GT 1 01-12-2008 03:49 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
Brakes....... SexyStang Pre-2005 V6 Mustang 3 05-05-2003 09:03 AM
01:53 PM
