any of u buy this stuff: - Mustang Evolution
Old 06-25-2012, 01:41 PM   #1
Silversky545's Avatar
I'm getting ready to replace a bunch of stuff on the car... for a tune up... just seeing what your opinion is on:
Coil plugs
Frpp spark plugs
New.polyethylene bushings every where
Silversky545 is offline   Reply With Quote
Old 06-25-2012, 01:57 PM   #2
garbill2003's Avatar
Motocraft or axcell or msd that's your call but I don't replace cops unless they are bad motocraft plugs bushings why ?
garbill2003 is offline   Reply With Quote
Old 06-25-2012, 02:35 PM   #3
Re: any of u buy this stuff:
stay ford OEM for coil packs and plugs, dont go aftermarket as many have issues. As far as plugs make sure they are not the ones that are known to break in half.
Many 05+ GT's have had plugs break in half on removal, its just how they are so be CAREFUL. Even if you let Ford do it, and they know about this.... they will still charge you 100-200 PER plug that breaks regardless if its a design flaw on their part or not
Bushings, Poly is fine but Delrin is better in many ways, you get a worse ride though so its a trade off. Go to maximum motorsports and review their product offerings and info. AmericanMucle has discounts for forum members so you can buy their stuff from AM.com's site and save as well.
Old 06-26-2012, 05:59 AM   #4
RedGT's Avatar
I have poly engine mounts, upper and lower Rear ctrl arms and shifter. Gave me a 25% increase of fuel mileage with my 91 tune. Huge power to the ground difference, and no wheel hop. Go for it.
Keep in mind that the ride will be stiffer with poly though. But it's worth it. Just grease them properly during the install.
RedGT is offline   Reply With Quote
Old 06-26-2012, 06:01 AM   #5
deadsp0t's Avatar
Bushings gave you 25% better mpg?
That's unimpressive
Old 06-26-2012, 10:39 AM   #6
RedGT's Avatar
Ford uses cheap rubber bushings. Try this for fun. Open the hood of your car, rev the engine to 4500 rpm or higher and watch how much the engine moves. Each time you accelerate the engine compresses the mount before putting power to the ground. Same happens with the ctrl arms. By using poly bushings there is significantly less movement and the body of the car is moved much sooner because there is no give in the bushings. All that to say the car takes off faster everytime, wasting less power in the bushings. Add this to a tune and you can get a huge gain in mpg.
Old 06-26-2012, 10:54 AM   #7
Lorraine's driver
ab_mach1's Avatar
I could see the trade off being that your engine is absorbing more impact than with the stock bushings. Is that bad?
Instagram: @ab_mach1
Old 06-26-2012, 11:55 AM   #8
deadsp0t's Avatar
What kind of mpg are you getting? 25% seems like a huge increase.
That's unimpressive
Old 06-26-2012, 12:27 PM   #9
RedGT's Avatar
The engine does take a bit more of a beating but I have 80K and no issues.
Old 06-26-2012, 01:18 PM   #10
Lorraine's driver
ab_mach1's Avatar
Cool!
Old 06-26-2012, 01:40 PM   #11
RedGT's Avatar
I get 24.5 in the city and 29.7 hwy. The increase is partly due to the tune as well, but between the tune and bushings it's a huge difference. Keep in mind I'm also at 2000' above sea level too.
06:26 PM
