idle problem - Mustang Evolution
Old 06-28-2012, 06:05 AM   #1
07regency's Avatar
idle problem
Has anybody else had this problem? When i start the car it wont run unless i give it gas to keep it alive if not it just dies. Even while driveing and coming to a dead stop it will die. Really would appreciate some feed back.
07regency is offline   Reply With Quote
Old 06-28-2012, 07:42 AM   #2
Jake's Avatar
Do you have a Bama Tuner??
Jake is offline   Reply With Quote
Old 06-28-2012, 07:47 AM   #3
07regency's Avatar
No no tune just cai and exhaust
Old 06-28-2012, 07:47 AM   #4
Lorraine's driver
ab_mach1's Avatar
If you are not showing a check eng light, you can try the idle re-learn first. Easy stuff first
Disconnect NEG from battery for 30min
Reconnect and start car, let idle as eng gets to operating temp. Let it idle a little over a minute
Turn on A/C to MAX, let idle little over a minute, turn off A/C
Then drive the car for at least 10 miles
Instagram: @ab_mach1
Old 06-28-2012, 07:56 AM   #5
Jake's Avatar
I would try what Azure said. I just know some people were having idle problems with their bama tuners. Hope you get it figured out bud!
Old 06-28-2012, 11:38 AM   #6
07regency's Avatar
I tried it and it didnt work. I scaned it and i have a misfire and P050E code- cold start engine exhaust temp outta range. How do i fix this problem
Old 06-28-2012, 11:50 AM   #7
Lorraine's driver
ab_mach1's Avatar
Check your IAC to make sure the wiring is not damaged or unplugged. If its plugged in ok and wiring not damaged, it probably needs to be cleaned, maybe replaced. You should double check your air filter and make sure it's not plugged too.
Old 06-28-2012, 02:02 PM   #8
07regency's Avatar
What is the IAC?
Old 06-28-2012, 02:53 PM   #9
Lorraine's driver
ab_mach1's Avatar
[QUOTE="07r[COLOR="Silver"]
---------- Post added at 04:53 PM ---------- Previous post was at 04:23 PM ----------
[/COLOR][QUOTE="Azure"][QUOTE="07r[/QUOTE]
iPhone app crashed...
The IAC is the idle air control valve. On my Mach1, it's attached to the throttle body. I'm not sure on 07's, but it should be on or near the throttle body vicinity. You can take this off and clean it with throttle body cleaner.
03:36 AM
