Oil Topics...what do you use? - Mustang Evolution
Old 02-22-2008, 01:11 PM   #1
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
Any of you guys ever used Royal Purple? And what type of oil do you generally use? 10w40? 5w20? I really have no idea what the 05 mustangs are suppose to take. i'm just now getting to where i'm changing my own.
braumab is offline   Reply With Quote
Old 02-22-2008, 01:22 PM   #2
Herbstang's Avatar
Re: Oil Topics...what do you use?
Never used the purple .I use Mobil 1 5W20 .The car comes factory filled with Motorcraft synthetic blend ford recommends 5w 20 synthetic blend motor oil.(which is the recommended oil in the manual). Note that synthetic blend is NOT the same as full synthetic.
Old 02-22-2008, 01:24 PM   #3
braumab's Avatar
Region: Arkansas
so then i need to use a synthetic blend?
Old 02-22-2008, 01:27 PM   #4
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
I use Mobil 1 synthetic.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 02-22-2008, 01:32 PM   #5
Herbstang's Avatar
No you can use whatever you want I just posted what the car came with
click on the link below and you'll see whats the right oil for my car fill in the in fo
What's the right oil for my car?
Old 02-22-2008, 01:34 PM   #6
Herbstang's Avatar
The 10 myths of synthetic oil. Good article if you never used synthetic oil before.
Old 02-22-2008, 01:52 PM   #7
Danger Dude's Avatar
I have more oil experience than 99.9% of the people on just about any site. What Herbstang posted is the absolute fact on synthetic oil. I have posted on this site and others facts on oil types and what is myths or just plain untruths. Synthetic oil is superior to conventional oil in every application and usage. Brand difference is not even an issue. In test I was a analyst in found the difference in synthetic oil is not even worth reporting. Whether Amsoil, Royal Purple, Mobil One, Havoline, Castrol, Penzoil, Quaker State, Valvoline and a few more oils I forget at this moment are all quality Synthetic products. It is all in preference. I have always been a Castrol user way before the Synthetics were around and still use it 90% of the time but I have tried just about every product out there. 2 oil changes ago I used Amsoil. Filters are another thing you can spend 3.99 or 12.99 on a filter and they all do the same thing and when you change the oil you throw them out. What you are willing to pay is up to you but I mostly use Motorcraft or Fram filters.
Old 02-22-2008, 02:14 PM   #8
I've always stuck with mobil1 5w30/20 synthetic...
Old 02-22-2008, 02:20 PM   #9
braumab's Avatar
Region: Arkansas
awesome. That helps quite a bit. Thanks for the reply back.
Old 02-22-2008, 02:34 PM   #10
ChrissyStang02's Avatar
Region: Iowa
Send a message via MSN to ChrissyStang02 Send a message via Yahoo to ChrissyStang02
+1, Mobil 1 5W20 for me too. Seems to work and keeps the engine happy, that's what's oil is supposed do.
My baby...
No, it's not my boyfriend's car and no, you can not drive it.
2002 Mineral Gray Mustang GT ~Dominic~
MagnaFlow Catback Exhaust, CAI, Mach 1 Grille Delete and much more to come. ***Sold. New 5.0 GT coming soon!!!
ChrissyStang02 is offline   Reply With Quote
Old 02-22-2008, 03:08 PM   #11
braumab's Avatar
Region: Arkansas
alright. Isn't there like a platinum or high end that mobil 1 makes? Can anyone elaborate on that why it's the better choice? if it's the better choice?
Old 02-22-2008, 03:29 PM   #12
Herbstang's Avatar
The Man Has Spoken !!!! End of Subject
Old 02-22-2008, 08:45 PM   #13
Aidan_04's Avatar
Mobil1 5w20 bish.
goodstuff.
2004 redfire 4.6L GT / 1994 rio red v6 vert / 1990 7UP LX vert
2804
^^^my fave V8 chick ^^^
Old 02-23-2008, 07:47 AM   #14
I use Mobil 1, I am sure Royal Purple is great I have just heard more than one issue come up after using it but of course no direct link to it being the problem~ I think the 4.6L is a funny motor when it comes to oil and its tolerances
Old 02-23-2008, 07:14 PM   #15
Scut95's Avatar
I know if i run full synthetic in my 5.0, it ends up running out the rear main seal and the drain plug seals, even with brand new ones in there.....i end up running regular castrol or valvoline (5W-30 in winter and 10W-30 in summer) and a motorcraft filter......I would not recomend Fram filters though, i cut one apart and there is not nearly as much guts inside compared to say a motorcraft and its the same price for either one.
Old 02-23-2008, 08:44 PM   #16
actually filters can make some difference and i stay away from fram
Opinions and Recommendations - Oil Filters Revealed - MiniMopar Resources
i use the mobil 1 filter.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 02-23-2008, 09:26 PM   #17
rocknbronco's Avatar
I have used Valvoline, Amsoil and Mobile One Synthetics in my 5.4 over all I have been pleased with Mobile. You can tell in a car using anything less that full synthetic if you spent alot of time in a quick lube like me. Other crap just seems to gum up in the never engines of course if you look at things like temp and oil passage size then you will realize while.
On the filter topic get a K&N or Mobile filter.
rocknbronco is offline   Reply With Quote
Old 02-24-2008, 11:37 AM   #18
sledgehammer's Avatar
Send a message via Yahoo to sledgehammer
I have heard its bad to switch frm conventional to synthetic after the engine has run conventional all its life. Is this true? would I be okay to go to a blend then to full?
94 v6 manual, 3.45s w/t-lock, cai, straight straight through dual exhaust, sct eliminator.
sledgehammer is offline   Reply With Quote
Old 02-24-2008, 01:47 PM   #19
Its bs plain and simple, if you use a higher mileage full synthetic you will be alright, the basic issue is the size of the molocules were conventional oils cary insize synthetic is one uniform size- it can cause leaks in older vehicles pre 80's I have put it in an 289 in a 67 Mustang with no issue at all. Valvoline has a Maxlife Synthetic that works well for 5K to 6K I use this in my wifes Tundra and I have used it for years, also Mobile One has just released a high mileage full synthetic.
For what your going with use the full synthetic and dont listen to the idiots out there whom preach conventional oil is great and the synthetic will fry your engine its simply not true, we have a better product on the market and it will save you money in the long run.
Old 02-24-2008, 04:21 PM   #20
Well my engine is actually 3000 miles new. but I just wondering if I can straight up switch to fully synthetic. (I am looking for a yes or no) I just dont want to **** up.
Thanks
Old 02-24-2008, 04:26 PM   #21
Yes it wont mess anything up refer to my previous post.
Old 02-24-2008, 04:55 PM   #22
mobil 1 and bosch filters are the same made my champ labs. wix makes good filters too and they make the filters for napa also and then purolator pure one is very good also. those are the only three filters i would use.
Old 02-24-2008, 05:07 PM   #23
Thank you.
Old 02-24-2008, 07:27 PM   #24
No prob.
Old 02-24-2008, 07:36 PM   #25
:yup: ever since my stang was new thats all i ran........i think the first few oil changes i ran motorcraft
Kyle is offline   Reply With Quote
Old 02-24-2008, 08:56 PM   #26
braumab's Avatar
Region: Arkansas
yeahhH!!
Old 02-25-2008, 12:07 AM   #27
Thomas91169's Avatar
royal purple whore here. ive been running RP in all my lubricants since i did the big 3 (oil, tranny and diff) back when i had my 02 GT and was thoroughly impressed with the numbers my butt-dyno was reading.
vice-a-versa, from what i recall, its fine to go from conventional to synthetic, but switching from synthetic back to conventional could pose issues.
-Thomas-
Old 02-25-2008, 08:58 AM   #28
braumab's Avatar
Region: Arkansas
hardcore!
Old 02-25-2008, 01:49 PM   #29
What I think is most strange is so many people run 5w oil in their cars in the south. The only reason for such light oil is CAFE "coporate average fuel economy" standards. They tweek oil every big of MPG they can to report fuel economy of a models of car and trucks in there average. I will run 10w30 all year simply put it is better viscosity in hot climate of the south and south west. I am not saying 5w is going to ruin the car just a personal opinion shared by many
Old 02-25-2008, 01:54 PM   #30
braumab's Avatar
Region: Arkansas
i could always research this but i'll just ask you guys..
what does the 5w mean and the 20 as well? I thought it was how well it ran in the cold vs. the hot?
Old 02-25-2008, 02:05 PM   #31
First number 5 means vicosity cold
W means Grade of oil
30 is warm temp viscosity
It is never really that cold south of the Mason Dixon line to need 5w but if you live in the great white north of Wisconsin or North Dakota thats another story.
Old 02-25-2008, 02:16 PM   #32
Yes most assume 5W the W stands for weight, thats not true.
'W' signifies the winter rating of the oil, showing how it will perform in cold weather. The lower the number prefixing the 'W', the lower the temperature the oil can withstand. Thus 10W- indicates a lower viscosity at low temperature than 20W-. The second figure shows the viscosity at 100 C, which is close to the bulk oil temperature in most water-cooled engines.
Old 02-25-2008, 02:37 PM   #33
braumab's Avatar
Region: Arkansas
ooooohhh, well that makes a plenty of sense now. Thanks guys ... it never really gets below 30 here. It has to REALLY try to hit 30.
Old 02-25-2008, 05:20 PM   #34
Just keep with the factory recomended weight of 5w20.....
Old 02-25-2008, 10:35 PM   #35
braumab's Avatar
Region: Arkansas
absolutely.
Oil upton7 The Bar 0 12-27-2009 04:27 PM
which oil upton7 1996-2004 Mustang GT 11 04-08-2009 09:21 AM
oil carlosc Pre-2005 V6 Mustang 46 02-25-2009 07:35 PM
2 Intresting Topics in 1 Thread bluemustang The Bar 20 03-28-2007 10:52 PM
Oil 00BlackStang Pre-2005 V6 Mustang 3 06-19-2006 01:14 PM
07:54 AM
