07-10-2012, 11:11 PM
#1 | | Registered User
| New head unit
Just installed this baby and it sounds sweet with my shaker 1000. This is what it should of sounded like stock.
07-11-2012, 10:22 AM
#2 | | Registered User
Looks good too! The stock stereo should be much better than ford made it.
05 GT Premium
Returned to almost 100% stock. Just 4.10's JLT CAI and Bamma 93 R tune.
07-11-2012, 10:38 AM
#3 | | Registered User
| Quote: |
Originally Posted by Jgill1992 Looks good too! The stock stereo should be much better than ford made it. | Thanks, it does look really good. It's nice having Bluetooth phone and audio too.
07-11-2012, 10:44 AM
#4 | | Registered User
| Re: New head unit
I installed the Pioneer AVIC X940BT 2 days ago and with the full EQ and different Bass adjusters and frequency settings, you would swear I swapped the speakers and subs out, too. Sounds amazing!!
06 GT - JLT 110MM - 4.10s - Steeda Under drive Pulley - FRPP manifold - FRPP TB - Shaftmasters Aluminum Driveshaft - Brenspeed Detroit Rocker Cams - Pypes Long Tube Headers - Pypes Catless X Pipe - Pypes Violator mufflers - 93 Dyno Tune 371WHP/332WTQ |
07-11-2012, 11:35 AM
#5 | | Registered User
| Quote: |
Originally Posted by Caster Troy
Thanks, it does look really good. It's nice having Bluetooth phone and audio too. | Yea I upgraded mine 2 days after I got the car. Never regretted it.
05 GT Premium
07-12-2012, 06:19 AM
#6 | | Registered User
Is that the Pioner avh p4400bh??? If so......... Heres mine!! |
07-12-2012, 06:20 AM
#7 | | Do The Evolution
Damn, those look good!
__________________ |
07-12-2012, 06:26 AM
#8 | | Registered User
| Quote: |
Originally Posted by primer2tone Damn, those look good! | Thanks!! Just put it in, its not done yet tho, it was dark when we put it in so i get fix the fitting a little better and i didnt hook my bluetooth mic up yet so i need to do that too!
07-12-2012, 12:58 PM
#9 | | Registered User
| Quote: |
Originally Posted by Jake Is that the Pioner avh p4400bh??? If so......... Heres mine!!
| Yes it is, sweet!
07-12-2012, 01:03 PM
#10 | | Registered User
| Quote: |
Yes it is, sweet! | Do you have the relay??
07-12-2012, 01:06 PM
#11 | | Registered User
| Quote: |
Thanks!! Just put it in, its not done yet tho, it was dark when we put it in so i get fix the fitting a little better and i didnt hook my bluetooth mic up yet so i need to do that too! | I had to use 2 washers behind each mounting bolt for the unit to eliminate the gap on the sides. Depends on the thickness of the washer, you may only be able to use one. I also wired the ground wires to a relay so I can play DVDs while driving. I have my mic sitting right on top of my steering column, and it works perfect and you don't have to run the wire far, it stays hidden behind the trimming.
07-12-2012, 01:25 PM
#12 | | Registered User
| Quote: |
I had to use 2 washers behind each mounting bolt for the unit to eliminate the gap on the sides. Depends on the thickness of the washer, you may only be able to use one. I also wired the ground wires to a relay so I can play DVDs while driving. I have my mic sitting right on top of my steering column, and it works perfect and you don't have to run the wire far, it stays hidden behind the trimming. | Mine has a gap at the top, how would i fix that??? And thats prob where im gonna put my mic too, post a pic of where your mic is
07-12-2012, 01:47 PM
#13 | | Registered User
| Re: New head unit
My crutchfield kit left 0 gaps. On My AVIC X940 I grounded the parking brake wire to the main ground and remote and that is it. GPS and DVD unlocked during movement.
07-12-2012, 02:25 PM
#14 | | Registered User
| Quote: |
Mine has a gap at the top, how would i fix that??? And thats prob where im gonna put my mic too, post a pic of where your mic is | You have to play with your face trimming to lessen the gap, there is a tap at the top where the power outlet is, make sure you have it lined up best as you can.
07-12-2012, 02:27 PM
#15 | | Registered User
Sorry, i meant to say tab. Lol.
07-12-2012, 02:39 PM
#16 | | Registered User
| Quote: |
You have to play with your face trimming to lessen the gap, there is a tap at the top where the power outlet is, make sure you have it lined up best as you can. | Okay, i will work on it saturday, my relay is coming in so ill be doing that along with the bluetooth mic. Did you use the trim piece that came with your head unit?? Or just the dash kit??
07-12-2012, 02:40 PM
#17 | | Registered User
| Re: New head unit
Same place I put my mic
07-12-2012, 04:12 PM
#18 | | Registered User
| Quote: |
Okay, i will work on it saturday, my relay is coming in so ill be doing that along with the bluetooth mic. Did you use the trim piece that came with your head unit?? Or just the dash kit?? | No, I just uses the dash kit.
07-12-2012, 04:26 PM
#19 | | Registered User
Looks awesome!! I have the AVH p3300BT.
07-12-2012, 05:31 PM
#20 | | Registered User
| Quote: |
No, I just uses the dash kit. | Okay just making sure!! Ill put another pic up when everything is done!
07-12-2012, 08:31 PM
#21 | | Registered User
| Quote: |
| That thing looks nice. Where do you get one of those?
07-12-2012, 10:37 PM
#22 | | Registered User
| Quote: |
Originally Posted by Roger07GT
That thing looks nice. Where do you get one of those? | Got mine off SonicElectronix, 444, includes dash kit, wiring harness, and antenna adapter
07-13-2012, 01:56 AM
#23 | | Registered User
| Quote: |
Got mine off SonicElectronix, 444, includes dash kit, wiring harness, and antenna adapter | Cool. Thanks. I'll check it out
