06 saleen rear end clunk going to smash car soon - Mustang Evolution
Old 07-14-2012, 10:36 PM   #1
ok I swear this car is trying to commit suiside and i am about to help it my 06 mustang got bad gas i replaced everything got new spark plugs the tool to take the broken pos out then my damn clutch goes out so we put a stage 4 race clutch in the sob and changed all fluid including rear end had the car back to running since july 4th well now ten days later my rear end is clicking very noisily when i take left hand turn I am about to push my tree over onto it and be done does anyone know what the problem is this time please help save this car
abell146 is offline   Reply With Quote
Old 07-14-2012, 10:41 PM   #2
DaBluedude's Avatar
Take the rear end apart... prob a set of spider gears. Mustangs require maintenence. Fact of life. Sounds like you've just been doing the usual stuff. Don't get frustrated. If its your only car then park it for awhile and get a beater. Oh, and a stage 4 race clutch is not for a street car at all. If you want to sell it for cheap let me know haha.
2003 Mach 1
Old 07-14-2012, 10:57 PM   #3
Re: 06 saleen rear end clunk going to smash car soon
twenty grand and its yours
---------- Post added at 10:57 PM ---------- Previous post was at 10:51 PM ----------
why is it only making noise while turning left in first gear
Old 07-15-2012, 10:55 AM   #4
Stang.racr's Avatar
Got any pics of the saleen
having a fine car that is slow is like having a hot girlfriend that won't put out!
Stang.racr is offline   Reply With Quote
Old 07-15-2012, 11:29 AM   #5
tc x 4's Avatar
Originally Posted by DaBluedude
Take the rear end apart... prob a set of spider gears. Mustangs require maintenence. Fact of life. Sounds like you've just been doing the usual stuff. Don't get frustrated. If its your only car then park it for awhile and get a beater. Oh, and a stage 4. race clutch is not for a street car at all. If you want to sell it for cheap let me know haha.
I've got to agree with a bad spider gear .
Old 07-15-2012, 06:57 PM   #6
ok i hope that worked to add a picture i think my problem is my clutch packs my ford guy says they can favor one side to the other and she still goes fine i just better be going straight lol
Old 07-15-2012, 07:00 PM   #7
my guy also said i need to add special fluid it and go do sharp turns to work it through does this mean he just told my to go spin donuts in a parking lot lol this girl cant wait for that it would be the best fix ever!
Old 07-15-2012, 07:27 PM   #8
Did you add any friction modifier? The clutch packs require it. They are around $6 a bottle from ford and only take one per rear. Auto stores have some but i always stick with oem.
Rear end fluid should be changed every 50k as it will collect water from the atmosphere and stop being as effective.
Old 07-15-2012, 07:30 PM   #9
yes i have it on order i am hoping it takes care of the problem thr fluid was just changed but my husband did not know about the friction mod so now we know and will do it and hope it takes care of it
Old 07-15-2012, 07:35 PM   #10
Even if the clutch packs are shot it's not a hard rebuild. There should be a few videos on youtube with step by step instructions.
Old 07-15-2012, 07:42 PM   #11
tc x 4's Avatar
I still believe It's a spyder gear, please let us know the fix.
---------- Post added at 09:42 PM ---------- Previous post was at 09:40 PM ----------
Spider, I've been a drinkn
Old 07-15-2012, 07:45 PM   #12
You just have to rebuild the locker. Still not that hard to do, it's the same procedure to replace clutch packs.
Drain diff, remove cover. Remove c clips and pull axles. Unbolt locker and remove attempting to save spacers on either side. Rebuild unit and reverse steps. If you have to pull pinion gear be sure to get a new crush washer and have backlash checked by a professional to prevent gear damage.
This would be the perfect time for a gear swap if you've been debating it.
Old 07-15-2012, 07:50 PM   #13
tc x 4's Avatar
Clutch packs slipping I don't think would make a clunck
Old 07-15-2012, 08:11 PM   #14
oh i will def let everyone know the fix
Old 07-17-2012, 04:53 PM   #15
ok the friction mod made it worse it did it driving down the freeway today
Old 07-17-2012, 07:02 PM   #16
BaSohol's Avatar
Dude just stop driving it and drop the pan!!!!! Your more then likely making everything way worse
---------- Post added at 08:02 PM ---------- Previous post was at 08:00 PM ----------
You should just take the cover off and inspect everything, it's soo easy, smelly but easy
2007 Ford Mustang GT 5spd
Old 07-17-2012, 10:26 PM   #17
ya i am parking her ordered a new limited slip diff and new royal purple fluid and brakes gaskets might as well damn gotta drive a van now for a while maybe ill take out the mopar for awhile that thing never breaks
Old 07-19-2012, 11:51 AM   #18
Send a message via AIM to Borii
CV joins on DS is also a possibility or lash in the gear set.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 07-29-2012, 11:05 PM   #19
and tcx4 wins it with the spider gears they are super chewed
Old 07-30-2012, 07:05 AM   #20
Solomo2's Avatar
How did you figure this out? May sound like a stupid question, but the rear end of my mustang makes a clunking noise as well and I am trying to figure out what it is. Also how much is it going to cost to fix?
Solomo2 is offline   Reply With Quote
Old 07-30-2012, 08:34 AM   #21
tc x 4's Avatar
Pull the cover and look. You can catch the oil and alls you'll be out is some silicone sealant. If its a gear you'll find peices in the bottom . The longer you wait, the more it will cost.
Old 07-30-2012, 09:08 PM   #22
i removed my diff cover and and spun my tire with my leg so i could watch my gears move slowly and saw the spiders gears teeth were chewed up i ordered a whole new limited slip diff for 300 with the upgraded clutch carbon clutch packs amd my royal purple fluid and a gasket and i may not be done my ring and pinion look great so that is good and me rear axles still spin and posi still locks so this should be it for me but i am repairing it myself tcx4 said about 300 to 500 plus materials and i would trust him hell he knew what my problem was what exactly is your doing and when and at what speeds
Old 07-30-2012, 09:16 PM   #23
ok these are my spider gears not looking so hot
Old 07-30-2012, 11:51 PM   #24
tc x 4's Avatar
When you pull the axles, you might want to stick an air hose in the end and blow it out just to make sure no pieces are lying in there. You'll be able to look inside the axle tube once It's removed. Good luck young lady
Old 07-31-2012, 12:46 AM   #25
thank you tcx4 i will do!
Old 08-06-2012, 09:10 PM   #26
ok limited slip installed and back on the road thanks guys
Old 08-06-2012, 09:50 PM   #27
Solomo2's Avatar
Which did you end up going with?
05:25 AM
