Stock radio question - Mustang Evolution
Old 07-27-2012, 06:54 AM   #1
Justintriner's Avatar
Can I hook my subs up to my stock radio or do I have to get another one?
Justintriner is offline   Reply With Quote
Old 07-27-2012, 07:11 AM   #2
Forum Car Trader
90GTNovi2000's Avatar
You should be able to.. Pull out the radio the wires will be labeled most of the time and they will say sub.. If not you can feed a amp off your radio and run the speakers to it..
---------- Post added at 08:11 AM ---------- Previous post was at 08:11 AM ----------
Where in TX are you? I live in ft. Worth..
90GTNovi2000 is offline   Reply With Quote
Old 07-27-2012, 10:02 AM   #3
Houston. I mean I have an after market radio abd I know how to do all that stuff I was just checking cause I didn't want to have to buy a holder for my aftermarket one if I could jus get away with using t stock one
Old 07-27-2012, 10:31 PM   #4
Yeah I just pulled everything out an there's no aux inputs for my amp. Good thing I bought the radio brackets just in case
Old 07-27-2012, 11:43 PM   #5
Saucywalnuts's Avatar
Can you hook up an amp and subs to a shaker 500?
Saucywalnuts is offline   Reply With Quote
Old 07-27-2012, 11:46 PM   #6
Jake's Avatar
Yes
Jake is offline   Reply With Quote
Old 07-28-2012, 12:37 AM   #7
Does it require lots of wiring or does it have the RCA cables and all that like an aftermarket stereo?
Old 07-28-2012, 05:17 PM   #8
I just finished all mine and when I pulled out the stick radio it did not have RCA inputs for subs so I had to put in my after market one
Old 07-28-2012, 05:27 PM   #9
Jake's Avatar
I had mine installed by a audio guy, and it was hooked up to my shaker 500, worked fine
Old 07-28-2012, 07:19 PM   #10
Redman4034's Avatar
I believe if you use the stock head unit you have to get an adapter to be able to run a sub. And if you use an aftermarket head unit you have to get a different adapter to run the door speaker amps. They will still work but the shaker system has amps to the mids and highs. So either way you need to acquire an adapter.
Redman4034 is offline   Reply With Quote
Old 07-28-2012, 07:46 PM   #11
Jake's Avatar
I believe your correct. I got a new head unit and sold my system anyway tho!
02:28 PM
