Lowering Springs - Mustang Evolution
Old 07-28-2012, 06:19 AM   #1
Roger07GT's Avatar
Region: Nevada
Lowering Springs
I've got an 07 GT I'd like to lower a little. ( 1 to 1.5 inches). Are lowering springs the way to go? And if so, is that something I can do in my garage?
Roger07GT is offline   Reply With Quote
Old 07-28-2012, 06:34 AM   #2
It's not me, it's you.
primer2tone's Avatar
Absolutely. You can do this yourself. Be sure to go with a quality spring set. I bought some cheap ones and my ride quality went down the crapper. I hear Eibach's are great.
Old 07-28-2012, 06:52 AM   #3
Roger07GT's Avatar
Region: Nevada
That's good. I like doing that kind of stuff myself. "You get what you pay for" good advice. Thanks
Old 07-28-2012, 08:04 AM   #4
Franco09GT's Avatar
I got the ford racing k-spring which lowered it 1.5 all around. Looks & feels great! Only thing I recommend getting is caster camber plates, cause when I put my springs on it moved my front wheels out & then I would be wearing out the inside of my tire instead of the tire being flat on the ground. & you will need a spring compressor to take off the front springs. If you got that you should be able to do it no problem.
Franco09GT is offline   Reply With Quote
Old 07-28-2012, 07:59 PM   #5
Silversky545's Avatar
K springs here as well... w supporting shocks n struts n front and rear sway bars your car will ride better than stock
Silversky545 is offline   Reply With Quote
Old 07-29-2012, 12:50 AM   #6
BaSohol's Avatar
Love my k springs as well
2007 Ford Mustang GT 5spd
Old 07-29-2012, 01:45 AM   #7
OMG we agree on something.... save this thread
Old 07-29-2012, 03:29 AM   #8
BaSohol's Avatar
Not true, you wanted to level yours with lower springs in the back. I like the unleveled stance with the K
Old 07-29-2012, 08:59 AM   #9
I didn't need a spring compressor because I'm a Boss.
Old 07-29-2012, 12:55 PM   #10
Zaks06GT's Avatar
You don't have to have camber plates, I would get the Eibach camber bolts, I'm lowered 1.6 front and 2.0 in back and it aligned fine.
Zaks06GT is offline   Reply With Quote
Old 07-30-2012, 08:52 AM   #11
Re: Lowering Springs
Yes, lowering springs are the way to go.
Yes, with the right tools and equipment (and experience) you should be able to do this in your garage.
There are other parts you may need/want, it just depends on what springs you choose.
For instance, our Sport/Ultralite springs (Sports = 1" [F] 1.25" [R] drop, Ultralites = 1.25" [F] 1.5" [R] drop) don't require any other parts, though I do highly recommend an adjustable panhard bar (to re-center the rear-end) and our heavy-duty upper strut mounts (to adjust camber).
SteedaBrandon is offline   Reply With Quote
Old 07-30-2012, 10:41 AM   #12
F4m0usfr34k's Avatar
I have Eibach's there great and look perfect with my 19" rims n tires ;D !!! Love em!
*f4m0usfr34k*
F4m0usfr34k is offline   Reply With Quote
Old 07-31-2012, 10:20 AM   #13
Send a message via AIM to Borii
How is this even possible?
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 07-31-2012, 10:38 AM   #14
BenGT07's Avatar
I have Eibach lowering kit on my 07 GT. Its a little stiffer, but handled great through the curves and looks way meaner IMO. MUST do the caster cambers though. I have the steeda's, and since I put them in, no issues with alignment.
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 07-31-2012, 10:50 AM   #15
I have k springs... you have k springs... how is it I want something different from you? If you are referring to a previous pistcabout swapping rear springs that's because in an out of corners level is better... uneven is better for straight.... I was simply testing the waters...
09:27 AM
