Help!! - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Old 07-30-2012, 07:27 PM   #1
Justintriner's Avatar
Justintriner is unknown around these parts
Help!!
Okay so after I put an after market stereo in my car I can't seem to get these light to turn off and idk why I've taken it all apart again and made sure all the plugs were in right and they still won't shut off any one have this problem before?
ID:	61482   Click image for larger version
Justintriner is offline   Reply With Quote
Old 07-30-2012, 07:37 PM   #2
Here they are again I think it messed up
ID:	61485   Click image for larger version
Old 07-30-2012, 07:49 PM   #3
Black05gt's Avatar
Black05gt is unknown around these parts
Did you check for blown fuses? Do they stay on all the time or are they off and on? No problems with my aftermarket stereo.
Black05gt is offline   Reply With Quote
Old 07-30-2012, 08:07 PM   #4
Which fuses? And no they stay on everything but the door light on the dash.(I had my door open when I took the picture) but my trc light will not switch off which i don't get because the hazard lights are controlled by the same plug and they work just fine. The hand brake will not turn off and and the abs light either. I've taken everything apart and put it back together exactly how it's suppose to be. I've even tried disconnecting the battery to try and see it would reset itself but no luck. I just don't want to take it to a dealership just so they can over charge me for something stupid and stupid ya know
Old 07-31-2012, 04:26 PM   #5
Black05gt's Avatar
Did you have to cut any wires? Or did everything plug in with adaptors? I would pull every fuse and just make sure they are all good.
Old 07-31-2012, 05:52 PM   #6
No I didn't have to cut any thing at all. But I can't see it being a fuse, if it was a fuse don't you think it wouldn't even come on at all? Because there would be no source of power cause it has to run through the fuse first
Old 07-31-2012, 06:00 PM   #7
Black05gt's Avatar
If you were to pull out a A.B.S brake fuse. Your A.B.S light would come on saying there is something wrong. Just check all the fuses it will only take ten min. And that's a good place to start. (And I'm only using the brake fuse as an example ) pull every fuse one at a time and check it!
Old 07-31-2012, 06:04 PM   #8
mustang06gt's Avatar
mustang06gt is unknown around these parts
Either you have the wrong adapters on, or you tapped into the wrong power source.
---------- Post added at 08:04 PM ---------- Previous post was at 08:01 PM ----------
Also, consider relays.
mustang06gt is offline   Reply With Quote
Old 07-31-2012, 06:40 PM   #9
Alright I'll check it out. I don't see how it could have tripped a fuse but I'll look. Thanks
Old 07-31-2012, 06:46 PM   #10
Jgill1992's Avatar
Jgill1992 is unknown around these parts
I installed a radio in my f150 a few years ago and I blew something and all the electronics went CRAZY. From then on I always pay $20-$30 for a shop to install it. Totally worth it
05 GT Premium
Jgill1992 is offline   Reply With Quote
Old 07-31-2012, 09:46 PM   #11
What kind of shop?
Old 07-31-2012, 09:48 PM   #12
Jgill1992's Avatar
A local audio shop here in my town. They only charged me $60 to install my touchscreen unit and the HPS box/antenna and the speaker for the Bluetooth. Some locally owned shops can give you pretty good prices if you shop around
05 GT Premium
08:37 AM
