Clicking from Dash - Mustang Evolution
Old 08-17-2012, 04:28 PM   #1
Aggiesrok's Avatar
Clicking from Dash
This just started this week. I turn the key and get a rapid clicking sound for 2-3 seconds. Then it started after the engine was running, same thing maybe 3-4 seconds. It sounds almost like a CD that is trying to eject. I emptied the CD player, turned off radio and turned off AC. No change, it still does it. There is no CEL or any indication that there is a problem, car drives normal. I can shut off the car and re-start and it happens every time. Anyone have a clue?????????
2007, GT/CS, 5sp, SCT -93 tune, CAI. Stock Shaker 500
Old 08-17-2012, 05:19 PM   #2
maldog's Avatar
Region: Nevada
Re: Clicking from Dash
Pull the fuse for the radio just to completely isolate the radio all together and see what happens.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-18-2012, 10:45 AM   #3
Artaz's Avatar
This happened to my car it was still under Warrenty so they fixed it it's nothing big I wish I remember what exactly it was
Artaz is offline   Reply With Quote
Old 08-21-2012, 11:28 AM   #4
Aggiesrok's Avatar
Not the radio. After the car is running, if you switch from AC to defrost and back, it makes the clicking sound. Is there a small servo for directing vents?
Old 06-09-2015, 01:09 AM   #5
Gravydog316's Avatar
mine just started doing this.
it says cd error
& also a clicking sound, which is probably the damper control
Old 06-09-2015, 02:20 AM   #6
natestang07's Avatar
3 year old thread lol
Old 06-09-2015, 08:19 AM   #7
Clicking from Dash
lol i saw that after I finished.
i was doing a search for how to remove the radio buttons, so I can replace my stock black ones with the later chrome ring ones, but all i can remove is the Power/volume knob.
Old 06-09-2015, 08:29 AM   #8
Kevin.Cook
Guest
Posts: n/a
For future reference, this issue is caused by the blend door actuators for the A/C system. On the 05-09 there are 3-4 of these in the dash. Over the course of a year or two, they have teeth that break off that cause a clicking. I replaced a couple of these in my 08 Mustang.
It will do it even if the AC is off.
Old 06-09-2015, 02:09 PM   #9
yeah, my '06 just started doing it.
then there was no air coming out of the dash vents, then it went CLICK CLICK CLICK & now it's working fine.
So, it'll stop working again on the hottest day of the year lol
my big brother is a mechanic, so i'll con him into fixing it 😉
thanks 👍🏼
is it hard to fix?
Old 06-09-2015, 02:12 PM   #10
Kevin.Cook
Guest
Posts: n/a
Depends on which one needs replacing. If you remove the glove box, you can get to 2 of them I believe on the passenger side. (Tight fit). I did not have an issue with the 2 on the driver's side so I couldn't offer any info on that.
The parts if I remember correctly, are fairly cheap.
Old 06-09-2015, 02:18 PM   #11
Clicking from Dash
the noise is on the passenger side
ok thank you!
Old 06-09-2015, 02:24 PM   #12
Kevin.Cook
Guest
Posts: n/a
Is it me or have you changed your picture 2-3 times today already? LOL!
Old 06-09-2015, 11:27 PM   #13
Clicking from Dash
i always change.
or "evolve"(?)
lol whatever.
...just bored
Old 06-10-2015, 05:07 PM   #14
the noise is coming from the 3rd vent (above the radio on the right side)
Old 06-10-2015, 05:43 PM   #15
Kevin.Cook
Guest
Posts: n/a
You could/should be able to take out the glove box/glove box door. Then you may need a flash light but if you look up inside, you should see it. I think you will need a socket wrench.
02:32 AM
