Error codes. Bad TPS? - Mustang Evolution
Old 08-20-2012, 07:34 PM   #1
Jgill1992's Avatar
Ok so my car keeps going into fail safe engine mode and runs as slow as a Honda I'm getting error codes p2106 p2135.
Says some **** about the TPS on my SCT tuner.
When I return car to stick it goes away..
---------- Post added at 08:34 PM ---------- Previous post was at 08:24 PM ----------
Guess its parked till bama opens tomorrow.
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 08-20-2012, 07:51 PM   #2
Re: Error codes. Bad TPS?
I know the slightest buildup in the drive by wire TB will cause TP codes,,They do it at work all the time,,I just clean them real good and everythings good
mymustang is offline   Reply With Quote
Old 08-20-2012, 07:59 PM   #3
Jgill1992's Avatar
I've got electric contact cleaner use that?
Old 08-21-2012, 12:57 AM   #4
1slosix's Avatar
can you test a tps on an s197 the same way as any other car with a multimeter? might not hurt if you can to test the volts
Old 08-21-2012, 07:38 AM   #5
Jgill1992's Avatar
I've got a multimeter. How do you test it? I guess it's time for a good old google search!
Old 08-21-2012, 10:52 AM   #6
Site Sponsor
Sponsor
AMWill's Avatar
Jgill1992,
Give you throttle body a good cleaning. This is somewhat common for 05-10 GT's having dirty a throttle body that mess with the TPS sensor. If you've been running your Bama tune for a while without any issues, it definitely makes me suspect something mechanical, then the tune.
Keep me updated on this issue, I want to make sure you turn out okay!
Shane
Toll Free: 866.727.1266
Free Same-Day Shipping!
Old 08-21-2012, 08:35 PM   #7
I know you can ,,just need a wire print,,but i always use a scanner to watch it,,guess im spoiled..The trucks at work you can remove the duct work ,,cycle the key and the throttle self checks itself,,if it dirty you can look closely,,and see it stutter just a little,,that will cause the computer to jump in fail safe mode after a few times..I use a citrius orange cleaner,,and carefully open up the plates and clean them out..Contact cleaner might be ok,,but i would research it a little
Old 08-22-2012, 06:18 PM   #8
Jgill1992's Avatar
I just ran a stragity tune and manually put in my 4.10's and disabled the cats. It's working ok but I miss the power and response from my bama tunes. Hopefually I'll get off work sometime when they are open and give them s call.
I don't think it's a physical problem the throttle body is clean and if the TPS was bad it shouldn still be showing bad no matter the tune right?
Old 08-27-2012, 11:32 AM   #9
Jgill1992's Avatar
Cleaned the throttle body and the MAD. Still doing it.. All voltages are good on the TPS.
ID:	65801   Click image for larger version
Old 08-27-2012, 11:40 AM   #10
BenGT07's Avatar
We have almost the same setup. I'm having issues too (thread idle surge) and several people have told me its that BBK TB. There's a lot of people that have issues with them apparently. I don't know for sure, but maybe try putting the stock TB back on and see what happens?
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 08-27-2012, 11:45 AM   #11
Jgill1992's Avatar
Also my fuel gauge totally craps out when using the tune...
I don't get idle surge at all on the stock tune.. And no error codes.. And the gays gauge works perfect..
Old 08-27-2012, 01:18 PM   #12
BenGT07's Avatar
Well, I tend to talk to random people a lot. I travel a lot so I get lots of practice. I was talking to a guy that works for a local performance shop about my issue, and the problem he had with the BBK TB, is he said it doesn't respond to tunes well.
Old 08-27-2012, 01:19 PM   #13
Jgill1992's Avatar
Hummm.
Old 08-27-2012, 08:27 PM   #14
Hummm.
Is the bbk messed up then
AGmustang11 is offline   Reply With Quote
Old 08-27-2012, 08:47 PM   #15
Jgill1992's Avatar
No it's a tune thing. I'm not sure anything can really "go wrong" with it. If anything the TPS might be acting up but that's not part of the TB.
Old 08-27-2012, 11:39 PM   #16
Okay but why does it act up but the tb is clean and it comes with everything
Old 08-28-2012, 01:22 AM   #17
Jgill1992's Avatar
It does the same error with the stock TB.
Old 08-28-2012, 08:10 AM   #18
BenGT07's Avatar
Well, it's gotta be the tune then. Or maybe just replace the TPS. It's only $111 or so and it takes about 3 minutes to change out.
02:56 AM
