won't start and threw codes 2110 and 2107 - Mustang Evolution
Old 08-22-2012, 07:26 PM   #1
07regency's Avatar
Anybody else had this problem? I went to the track that night ran good the whole time then the next morning wouldn't start. Replaced alternator and throttle body motor and.still nothing. Any suggestions or advice would " greatly" be appreciated
07regency is offline   Reply With Quote
Old 08-22-2012, 08:54 PM   #2
maldog's Avatar
Region: Nevada
Re: won't start and threw codes 2110 and 2107
I would reload your tune that you are running and see what happens. It sounds like something happened to your tune you had installed.
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 08-22-2012, 08:57 PM   #3
07regency's Avatar
No tune
Old 08-22-2012, 09:00 PM   #4
maldog's Avatar
Region: Nevada
Also, here is some additional info;
P2107 is a failure of the electronic throttle control test in the PCM. P2110 is an issue with the throttle actuator. Likely a throttle body problem but could be a failing PCM..
---------- Post added at 07:00 PM ---------- Previous post was at 06:57 PM ----------
Originally Posted by 07regency View Post
No tune
Ok....... No tune!
Something is happening with your PCM and the additional stuff I advised you about.
I would try to re flash your PCM with the stock tune and go from there.
Old 08-22-2012, 10:02 PM   #5
07regency's Avatar
And how would I flash it without a tuner?
---------- Post added at 10:02 PM ---------- Previous post was at 10:01 PM ----------
And how would I flash it without a tuner?!4
Old 08-22-2012, 10:12 PM   #6
maldog's Avatar
Region: Nevada
You would have to get your vehicle to a Ford Dealer. The best bet because you don't have any diagnostic tools is to get it to a shop. You will save money in the long run. Good luck.
Old 08-22-2012, 10:15 PM   #7
07regency's Avatar
Appreciate it man
Old 08-22-2012, 10:27 PM   #8
maldog's Avatar
Region: Nevada
Appreciate it man
You're welcome I hope you're back on the road soon.
09:18 AM
