cleaning throttle body - Mustang Evolution
Old 08-27-2012, 08:12 PM   #1
todd mulder's Avatar
i would like to add throttle body cleaning and fuel filter change to my maintenance list that i will do myself. how often should i perform and what is involved? 05 gt
todd mulder is offline   Reply With Quote
Old 08-27-2012, 08:18 PM   #2
McNassty's Avatar
Careful, be sure to check your throttle body for a sticker. Some throttle bodies are made with a protective coating and they are not supposed to be cleaned. If you do clean them you'll ruin that protective coating
McNassty is offline   Reply With Quote
Old 08-27-2012, 08:48 PM   #3
Re: cleaning throttle body
we'll do. thanks
Old 08-28-2012, 11:01 AM   #4
garbill2003's Avatar
Use throttle body cleaner and your coating will be fine and its up to yo when you want to clean it. I would say every twenty thousand miles or depending on where you drive it.
garbill2003 is offline   Reply With Quote
Old 08-28-2012, 12:37 PM   #5
Caster Troy's Avatar
Region: Hawaii
The mustang does not have a Teflon coating in the TB so you can clean as often as you want. It is good maintenance to clean your TB along with your fuel system every 15K or once a year. This will help maximize your fuel economy. As far as fuel filter, the manufacturer suggests that it be replaced every 30K. A little advise, don't totally remove the plastic cover when you replace the filter, just bend it down from the rear, it's kind of a ***** to put back on.
Caster Troy is offline   Reply With Quote
Old 08-28-2012, 06:16 PM   #6
McNassty's Avatar
Mine has a Teflon coating but mines a '95
Old 08-28-2012, 07:23 PM   #7
Region: Hawaii
Yes, but this is the 05-09 forum.
Old 08-28-2012, 07:43 PM   #8
BaSohol's Avatar
+300
2007 Ford Mustang GT 5spd
Old 08-28-2012, 08:51 PM   #9
Region: Hawaii
Originally Posted by BaSohol
+300
Lol
Old 08-28-2012, 09:41 PM   #10
Blogger
99ford's Avatar
I've done it no issues I used TB cleaner worked great
Fuel filter I have not done yet, but yeah you can bend the plastic back it has 2 connectors there looks super easy.
Old 08-30-2012, 08:18 PM   #11
thanks, does'nt sound too difficult
Old 08-30-2012, 08:48 PM   #12
Blogger
99ford's Avatar
Yeah, super easy.
I accidently found the fuel filter looking for something else. My mechanic charged me 75 for the filter change, 75 for the TB and 75 for the fuel injector cleaner and a through inspection. Ford wanted 800 for the same job.
---------- Post added at 10:48 PM ---------- Previous post was at 10:45 PM ----------
But you can do it all for less than 75. Check American Muscle and Rock Auto for the filter.. they seem to have the best price.
Old 08-30-2012, 08:53 PM   #13
Jgill1992's Avatar
Throttle body cleaner will NOT hurt the coating. Just make sure to use THROTTLE BODY cleaner. Not carb cleaner or other types of cleaner. The TB cleaner won't damage coating
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 08-31-2012, 02:53 AM   #14
McNassty's Avatar
Come on over to my house and I'll show you what throttle body cleaner did to my stock throttle body and how it was the thing that convinced my wife to let me buy a BBK 70mm throttle body.
Old 08-31-2012, 02:55 AM   #15
McNassty's Avatar
Oh and I used throttle body cleaner
Old 08-31-2012, 04:40 AM   #16
I use a citrus orange cleaner..Even if it ruins the coating,,it just means you have to clean more often,,If you go by the label,,you would have to replace the throttle body every 20000 miles,,instead of cleaning it..thats crazy,,If you let it get to dirty youll have drivability problems,,Ford uses throttle body cleaner,,even with the protective coating,,they say just say clean it more often,,if your worried about the coating,,then replace it when it gets dirty,,i know i wont,,ill just clean it more often,,I usually clean it out when i service the air filter,,the 05 to 09,,just carefully open the plates up,,dont force it to hard against the electric motor,,
mymustang is offline   Reply With Quote
Old 08-31-2012, 09:34 AM   #17
Region: Hawaii
If you turn the key in the on position and hold the pedal down the TB will open on the 05 and up. You should never manually open a drive by wire TB.
Old 08-31-2012, 08:53 PM   #18
Blogger
99ford's Avatar
But yours is Teflon ours are not... And everyone knows that you should only use soap and water, and a rubber spatula
I think you were predetermined to get the BBK and it was the only way you could ever convince your wife.
Old 08-31-2012, 08:57 PM   #19
McNassty's Avatar
Prolly, LOL!!!
Old 08-31-2012, 09:12 PM   #20
Blogger
99ford's Avatar
Prolly, LOL!!!
But I'd do the same if I had a wife
Old 08-31-2012, 09:20 PM   #21
nhcowboy's Avatar
I think I will go "clean" my intake manifold too... That way I have to get a supercharger NOW.
Thanks for the "cleaning" tip!!!
Ha.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 08-31-2012, 09:37 PM   #22
Blogger
99ford's Avatar
Ha.
If you get sent to the dog house it's not my fault. It's McNassty's
Old 09-01-2012, 06:01 PM   #23
McNassty's Avatar
Don't throw me under the bus. Oh wait, he lives in Texas, go ahead and blame me. She'd have to be pretty pissed to drive all the way to Missouri just to kick my ***, LOL!!!
09:45 PM
