Stiffening clutch - Mustang Evolution
Old 09-01-2012, 12:31 AM   #1
C_Dailey95's Avatar
Stiffening clutch
Is it possible to make the clutch stiffer? The one in my 07 v6 was stiffer than the one in my 06 GT. Being used to the stiffer clutch i prefer it over a loose one. So, is it possible?
C_Dailey95 is offline   Reply With Quote
Old 09-01-2012, 01:42 AM   #2
Silversky545's Avatar
Yes... aftermarket clutch...
I will add to your question:
Can you convert these dumb *** clutches to cable? And can you convert to a cable throttle?
Silversky545 is offline   Reply With Quote
Old 09-01-2012, 02:06 AM   #3
C_Dailey95's Avatar
I had a feeling that was the only way. I guess ill just have to deal with it for now. And are they hydraulic? I thought they were already cable, or is that just the v6's?
Old 09-01-2012, 02:26 AM   #4
I thought cables were just on 64-04 mustang's... I don't like the idea of how the clutch and throttle work electronically... I like to b n control
Old 09-01-2012, 02:48 AM   #5
C_Dailey95's Avatar
Hmm, im not to sure. I think i saw somewhere that they were hydraulic but im not 100% sure.
Old 09-01-2012, 03:13 AM   #6
Yes they are hydrolic... I'm not sure what that is per say but I do know I like the feel of cable clutches better
Old 09-01-2012, 06:50 AM   #7
BaSohol's Avatar
My stock clutch was really stiff, my new CenterForce is just as stiff, my buddy's 07 is very light tho
2007 Ford Mustang GT 5spd
Old 09-04-2012, 08:49 AM   #8
Send a message via AIM to Borii
Re: Stiffening clutch
My stock Clutch is very stiff. Also the clutch is hydraulic, therefore, NOT electronic.
SOLD - 06 GT 371WHP/332WTQ
Sold - 1998 Camaro SS
Sold - 2001 Audi S4
Borii is offline   Reply With Quote
Old 09-04-2012, 02:24 PM   #9
Gil_T2's Avatar
Cable clutch started with the mustang II in the late 70's. Before that the clutch was linkage setup. Hydraulic started in 2005. If you want a stiffer peddle buy a new pressure plate with heaver rating. All 3 setups have plus and neg affects, cables stretch and break, Hyd leak, as long as you can feel the engagement point that is all that matters.
And yes you can have cable throttle Ford makes it, also aftermarket makes parts to switch from Cable to Hyd and Hyd to Cable. What ever floats your boat..
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 09-05-2012, 09:09 AM   #10
MavyMav's Avatar
BaSohol, how do you like the Centerforce? And is it the DFX or Dualfriction? I know you race a little and I am looking into upgrading my clutch. Mainly need one for street and light strip use.
MavyMav is offline   Reply With Quote
Old 09-05-2012, 11:59 AM   #11
BaSohol's Avatar
I love the CenterForce DF, really good on the street and strip, I chirp 4th gear with it
08:28 AM
