Plasti dip questions???? - Mustang Evolution
Old 09-01-2012, 02:57 PM   #1
F4m0usfr34k's Avatar
Will water wash off the plasti dip on my car ???
*f4m0usfr34k*
F4m0usfr34k is offline   Reply With Quote
Old 09-01-2012, 02:58 PM   #2
1slosix's Avatar
Re: Plasti dip questions????
it hasn't washed mine off..it's been on there for about a month.
Old 09-01-2012, 03:01 PM   #3
Aight sweet man thanks!!
*f4m0usfr34k*
Old 09-01-2012, 03:10 PM   #4
alloy427r's Avatar
Is plastic dip that easy? Before buying a new front grill I want to black out the chrome pony. It works for that right?
alloy427r is offline   Reply With Quote
Old 09-01-2012, 04:31 PM   #5
Yes. Just make sure you mask off the area, because peeling the excess plastic off the grill would be a huge time sink.
ghst is offline   Reply With Quote
Old 09-01-2012, 04:45 PM   #6
Yea pretty easy just use tape to surround the emblem and cover the rest of the grill...
*f4m0usfr34k*
Old 09-01-2012, 05:07 PM   #7
Jboogie's Avatar
Where can u buy plasti dip?
Jboogie is offline   Reply With Quote
Old 09-01-2012, 05:11 PM   #8
nhcowboy's Avatar
I get mine from lowes
---------- Post added at 06:11 PM ---------- Previous post was at 06:09 PM ----------
Regarding the masking... I had trouble if you let the plasti-dip completely dry, then try to peel the masking tape off.
You almost need to do it within minutes of spraying your last cost... And always pull back and away from the sprayed areas... That will help prevent pulling up the rest of the sprayed areas.
2011 Black Mustang GT Premium
Corsa XO & Sport AB/Airaid/Bama 93R
Best 1/4 mile to date 60' 2.009
12.538 ET @112.33
100+ Deg 85 Hum RPR 3PM 1/2 tank street tires
nhcowboy is offline   Reply With Quote
Old 09-01-2012, 06:16 PM   #9
Yep agreed ... But lowes is where I purchased mine today
*f4m0usfr34k*
Old 09-02-2012, 08:21 AM   #10
Jboogie's Avatar
Going to Lowes to get a can we will see how it goes blacking out the horse on the grill. Any pointers?
Old 09-02-2012, 09:55 AM   #11
Just make try to cover as much as possible it's really easy to peel off but it's a bit of a pain when it's on the front grill wheres theres lots of little groves ... On ur emblem there's another trim that's right along the horse... I just taped off right around that... post pics alllllso u should hit up ur emblems
*f4m0usfr34k*
Old 09-06-2012, 01:02 PM   #12
TXstang125's Avatar
when I pulled my tape off it wasn't a clean tear so I'm going to redo it.What is the best way to get that clean edge when u peel the tape off??
TXstang125 is offline   Reply With Quote
Old 09-06-2012, 01:06 PM   #13
05MUSTANG4.0L's Avatar
Of course , I did mines
ID:	67411   Click image for larger version
05MUSTANG4.0L is offline   Reply With Quote
Old 09-06-2012, 02:00 PM   #14
I would say make ur coat thicker then ... I never had an issue with the lot cutting clear.... Also where u located ? Humidity and heat could play a factor ? Also make sure it drys well enough
*f4m0usfr34k*
Old 09-06-2012, 02:01 PM   #15
That's mine...
*f4m0usfr34k*
Old 09-06-2012, 02:03 PM   #16
Alonzo.dargan1's Avatar
^nice
Alonzo.dargan1 is offline   Reply With Quote
06:48 AM
