Cam Sensor CEL code - Mustang Evolution
Old 09-07-2012, 06:16 PM   #1
Cam Sensor CEL code
Hello,
I just purchased a used 2005 GT mustang a few weeks ago...just yesterday i started it and all of a sudden the CEL was on....i went to advanced auto and its saying the CAM sensor is lose or bad based on the code...however the engine is running perfect...no misses, timing doesnt seem out nothing...i disconnected battery to try an reset and it did come back on...
Anyone have any suggestions?? is the CAM sensor easy to change out???
The car does have a CAI and throttle spacer, and if theres anything else done to the motor im not sure....i assume whoever had it before me had to get it tuned?? Does that maybe have something to do with it?? I notice absolutely no difference in throttle response or power...
thanks soo much for your response!!
Shaun
ccna4481 is offline   Reply With Quote
Old 09-07-2012, 06:48 PM   #2
Mr. SoloDolo's Avatar
G
Mr. SoloDolo is offline   Reply With Quote
Old 09-07-2012, 08:22 PM   #3
F4m0usfr34k's Avatar
Cam sensors are super easy and cheap to change out ... However, I had a code saying my cam sensors were bad an I changed them and they ended up saying that I needed a new alternator :/ then two days later my battery died cuz of a bad alternator .... Soooooooo ur local auto store can prob order ur cam sensors .... U can look up on YouTube where to change them .... There's two of them... And it's just a bolt to unbolt then bolt back on super easy .... But if it continues to stay on I'd check ur alternator :/
---------- Post added at 09:22 PM ---------- Previous post was at 09:21 PM ----------
The parts here in AZ were like 17$ each not too bad
*f4m0usfr34k*
F4m0usfr34k is offline   Reply With Quote
Old 09-07-2012, 09:11 PM   #4
BenGT07's Avatar
I had the same issue, I did new CPS from pep boys and still had the code. Got the CPS from Ford and immediately code was gone. Quite a bit more expensive, but the OEM part worked... If it happened again, I'd probably try Pep Boys again though. $17 vs $48 or whatever.
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 09-07-2012, 09:25 PM   #5
Well I replaced my sensors then I have my tuner I cleared the codes and try eventually came back on So that's when I took it to ford and they said it was the alternator :/
*f4m0usfr34k*
09:26 AM
