Friggin' Fuse Box... - Mustang Evolution
Old 03-25-2008, 05:50 PM   #1
bbunt302's Avatar
The other day I was playing around with some of my instrument cluster settings on my '06 GT. Well, suddenly the lights went out on both them and my radio. It's strange... they work when the headlights and parking lights are off, but as soon as I turn on the parking lights they both go out.
So... I believe I have blown a fuse. Unfortunately, I cannot for the life of me figure out how to get in the goddamn fuse box behind the passenger side kick panel. The only way I see that it might be done would be to remove the entire freakin' kick panel, which I really don't wanna do.
So does anybody know any tricks before I just take this thing to the stealership?
BTW, this will be the last Ford I ever buy. The stupidity of their engineers these days is just too much.
Scary stuff.
Old 03-25-2008, 06:00 PM   #2
Re: Friggin' Fuse Box...
they moved the location of the fuse box?
Kyle is offline   Reply With Quote
Old 03-25-2008, 06:03 PM   #3
It's a whole new car
Old 03-25-2008, 06:18 PM   #4
apparently so...........used to be under the steering column area and under the hood. sorry to hear you have to take apart half the car to replace a 2 dolla fuse
Old 03-25-2008, 07:52 PM   #5
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Ok, what is the huge deal? Isn't it just a push pin you have to remove to get to the interior fuse box?
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 03-25-2008, 08:02 PM   #6
05RedDevil's Avatar
Also, if it were a fuse then there would never be electrical supply to any of the lights so long as the fuse if blown. I'm pretty sure that your display settings are just changed to be totally off. You know how you can change the "My color" settings. Well, they definitely are changed. Out of the 125 different RBG (Red/Blue/Green) values you have chosen the dimmest possible setting.
Some show. Some go.
Old 03-25-2008, 08:04 PM   #7
bbunt302's Avatar
No. You pop off a little plastic cover on the kick panel. Then there's another cover for the actual fuse box. It has two plastic tabs on each side that have to be pushed in so you can pull the cover off. The one on the right is impossible to get to because it sits back behind the kick panel. The hole isn't big enough to get to it.
Scary stuff.
Old 03-26-2008, 11:01 AM   #8
bbunt302's Avatar
Finally got to it. Had to pop off the passenger door scuff plate and kick panel. At least now they have some nice, sturdy metal clips holding those pieces in instead of the old, easily broken plastic ones. That's the main thing I was worried about.
Still, it makes me wonder what they were smoking at Ford when they put an access panel on the kick panel for the sole purpose of access to the fuse box... yet they didn't make it big enough to get the damn cover off.
Scary stuff.
Old 03-26-2008, 01:41 PM   #9
Herbstang's Avatar
I was consulting
Old 03-28-2008, 07:54 AM   #10
braumab's Avatar
Region: Arkansas
Send a message via AIM to braumab Send a message via MSN to braumab
05 Stang to the Bang! X-Pipe, Headers, Stage 2 Roush Kit, Tuner, JBA Exhaust and about a million and 4 Horsepower.
braumab is offline   Reply With Quote
Old 04-03-2008, 05:00 PM   #11
OsirisGuy's Avatar
I've found a lot of newer cars have split p their fuse boxes, half under the drivers column or kick panel and the other half in the other kick panel or side of the dash. Hell even GM (think Saturn) has some fuses on the passenger side center console.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
fuse box? braumab 2005-2010 Mustang GT 5 12-08-2008 03:29 PM
Engine Compartment Fuse Box mvp828 Pre-2005 V6 Mustang 1 10-20-2008 09:42 AM
That's a huge friggin guy Brent The Bar 16 03-08-2007 10:42 AM
change the fuse box cigarette lighter to turn off mexor The Bar 9 01-25-2004 03:10 PM
08:55 AM
