Stroker kit or Kenne Bell? - Mustang Evolution
Old 09-14-2012, 11:07 PM   #1
Graham1992's Avatar
Okay guys, I've been almost positive I want a Kenne Bell 2.6 stage 2 for a long time. I added up exhaust and suspension and necessary mods such as injectors, plugs, the boost a pump for my stock fuel pump and so on. All of it added up plus install was 11378.87. Well I got to looking around and NOW I'm on this new thing about a striker kit. If I decide to build instead of add on I can always get the KB later on. Any suggestions?
Graham1992 is offline   Reply With Quote
Old 09-14-2012, 11:14 PM   #2
gqsmash's Avatar
Doesn't seem like money is an issue so if it were me I'd build the motor first before boost...only because then you would know your internals are stout enough..
gqsmash is offline   Reply With Quote
Old 09-14-2012, 11:16 PM   #3
Graham1992's Avatar
So if I did choose to build it first it would pretty much be bullet proof? If not then what would go first, assuming I use the best striker kit money can buy.
Old 09-14-2012, 11:25 PM   #4
gqsmash's Avatar
Well I know you'll find our cars are safe at around 450 hp when boosted and most of the time people keep wanting more so incase you are like that...there was a guy on here that bent a forged rod, but I don't know what kind of boost he was running.
Old 09-14-2012, 11:49 PM   #5
Graham1992's Avatar
Well see that's the things, I have cams CAI full exhaust pulleys and a few other things and have 326.09 hp real wheels and I'm expected to have anywhere between 510 and 540rwhp which isn't so safe.
Old 09-15-2012, 12:24 AM   #6
MedicDave's Avatar
Should you decide to do a build you might be able to save a few bucks by using your stock crank, my mechanic told me our cranks are good to around 650 hp, so you just change out your pistons, rods and heads and you should be in the safe with boost. I'm going to put a blower on mine but I think I'm going to get forged internals first just to be safe. Good luck man keep us posted.
MedicDave is offline   Reply With Quote
Old 09-15-2012, 12:47 AM   #7
Caster Troy's Avatar
Region: Hawaii
Sounds like you have the cash to invest, you should check out that Brenspeed B326 stroker engine, I think it sells for around $5K. It is said to be able to handle up to 1000 HP and you can still use your stock heads.
Caster Troy is offline   Reply With Quote
Old 09-15-2012, 02:22 AM   #8
Graham1992's Avatar
Yeah wow I might actually just go with that if I go with the build, I've looked at it and it seems super cheap for what your getting. Anyone know what a stock transmission will hold HP wise?
05:30 AM
