Rattling in my rear lol... - Mustang Evolution
Old 09-18-2012, 10:01 PM   #1
F4m0usfr34k's Avatar
So I've just notice theres a rattle in the rear end of my stang when I hit little bumps or railroad tracks things like that ... Any suggestions on what it could be ?? I've checked the trunk to make sure there nothing in there... Lol but I'm thinking it could be the bumper or I got my car lowered a couple months ago do u think something could have came loose or broken ?.....
*f4m0usfr34k*
F4m0usfr34k is offline   Reply With Quote
Old 09-18-2012, 10:53 PM   #2
Jayjay's Avatar
Have you checked your exhaust
Jayjay is offline   Reply With Quote
Old 09-18-2012, 11:36 PM   #3
Yea It more of a loud rattle like a rumble ... :/ like something's loose or is bouncing ... Cuz I have had my mufflers rattle and I fixed them before but this don't sound the same ...
*f4m0usfr34k*
Old 09-18-2012, 11:52 PM   #4
It's not me, it's you.
primer2tone's Avatar
How's the rebound on your shocks? You could have a wheel bouncing when you run over bumps.
Old 09-19-2012, 02:20 PM   #5
righter86's Avatar
Re: Rattling in my rear lol...
I bought my 'stang a year ago and it took me a couple months to figure it out:
My car has aftermarket Flowmasters on and it seems like the passenger side pipe from the Y to the muffler rubs some kind of a support bar all the time. It was an annoying noise on any bump. I've put some rubber between the pipe and bar and went away instantly. Not sure why the pipe on the driver's side clears but not the passenger side.
Hope that helps.
2005 GT Premium
Flowmasters, Flat-Black Racing & Reverse C-Stripes, blacked-out GT emblem, Honeycomb Deck Lid & Tail Lights, Black GT Fuel Door, Axerra Bluetooth Radio w/ iPod, shortened stock antenna, S&B CAI, 18" 2010 GT Wheels, Halo Headlights
righter86 is offline   Reply With Quote
Old 09-19-2012, 11:47 PM   #6
Hmm that could be it ima get under her this Saturday to find out what it really is so I'll let y'all know ...
*f4m0usfr34k*
Old 09-20-2012, 05:43 AM   #7
garbill2003's Avatar
Yah i would look for marks I would also check the work that was performed earlier to make sure. Everything it tight
garbill2003 is offline   Reply With Quote
Old 09-20-2012, 05:45 AM   #8
Alonzo.dargan1's Avatar
+1
Alonzo.dargan1 is offline   Reply With Quote
Old 12-30-2012, 10:36 AM   #9
2012Coyote's Avatar
Hey OP, Did you ever figure it out? I recently noticed a rattling coming from mine as well.
2012Coyote is offline   Reply With Quote
Old 12-30-2012, 11:13 AM   #10
I figured it out for my car, but all could be different but what I figured out is that when my car recently got lower several months back... the pipes under my car sat a lot closer to the car and on bumps the pipes would rattle against the bottom of the car... this was the noise I was hearing... easy fix just had the guys down at ford move them around to where no pipes connected with anything else... let me know what happens!
*f4m0usfr34k*
Old 12-30-2012, 12:55 PM   #11
2012Coyote's Avatar
Thanks for the quick reply.
I climbed under the car to look for things mentioned in this thread. My exhaust pipe is rubbing the tub for the spare tire when I hit a bump, There is only around a 1/8" gap. It is probably from a combination of the 3" piping and the lowering kit (Pro-kit). I plan on jacking the car and trying to bend the pipe or the part of the tub it is rubbing.
Old 12-30-2012, 01:10 PM   #12
Yep that's exactly what mine was doing!! Hope that does it for ya! Mine went away after I did the fix
*f4m0usfr34k*
Old 12-30-2012, 08:09 PM   #13
GT Gone's Avatar
It's usually always been exhaust in my (or my friend's) case, I never got my exhaust rattle until.. Well, after my exhaust.
2008 Mustang GT/CS: 5 speed | FRPP 4.10 Gears | Bama 93H Tune | Magnaflow Magnapacks | Bassani O/R X Pipe | Airaid CAI | MGW | J&M LCAs (to be installed)
Upcoming: GT500 Supercharger (Department of Boost), 19" Koko Kuture Sardinia-5 Wheels, etc.
GT Gone is offline   Reply With Quote
Old 01-03-2013, 10:27 AM   #14
galindojr24's Avatar
I had the same problem only over bumpy roads, bumps, and rail road tracks.. Im going to school to be a mechanic and checked TSB'S for my 2007 and found alot of people had the same complaint i did and it was either you need new exhaust hangers or new lower control arms for the rear something about the bushings going bad plus it will reduce your wheel hop on launch and the aftermarket ones look alot better the stock ones are ****. I bought both because the noise was driving me insane and the noise is gone. Hope this helps..
ID:	83930   Click image for larger version
galindojr24 is offline   Reply With Quote
02:17 PM
