How much HP with my current mods? - Mustang Evolution
Old 09-27-2012, 10:49 PM   #1
CPauley's Avatar
So far I have a CAI long tube headers, Pypes offroad x-pipe and pypes midmuffler exhaust and a diablo t-1000 tuner..just curious..I have an 05 gt
CPauley is offline   Reply With Quote
Old 09-27-2012, 11:11 PM   #2
We could throw numbers around all day but the only real way to find out would be to dyno it. I would say with those mods you probably got around 30-40 HP/TQ
Old 09-28-2012, 10:34 AM   #3
OneSick07's Avatar
Maybe 330 I'd say more aroun 320-325 at the wheels tho.
OneSick07 is offline   Reply With Quote
Old 09-28-2012, 10:48 AM   #4
BaSohol's Avatar
Haha hell no, probably 280-290 at the wheels
2007 Ford Mustang GT 5spd
Old 09-28-2012, 01:35 PM   #5
Send a message via AIM to Destination S19
Intake and tune will grab you probably 15hp, longtubes should free up anything between 15 and 20 depending on the flow of the brand, i wouldn't expect anything from removing the cats except anything from 2-5 on the offroad x. If I had to throw out a guess, you're probably sitting on 280-290 at the wheels. Depending on the tune mostly, elevation and octane in the fuel.
FRPP HotRods Cams / American Racing Headers Long Tubes with catted X / Stang-Hi dyno tune
Saleen wheels / Steeda CAI / Corsa Xtremes, K Springs, Koni STR.Ts, UMI lca relo. Brackets/r lwr ctrl arms UMI adj. panhard bar / Camber plates / SR Strut Tower Brace.
Destination S19 is offline   Reply With Quote
Old 09-28-2012, 04:12 PM   #6
S197Miller's Avatar
+1 throw in some cams, delete plates, and underdrive pulleys and you'll be closer to 330 to the wheels.
S197Miller is offline   Reply With Quote
Old 09-28-2012, 10:06 PM   #7
BenGT07's Avatar
Yeah, I'd agree that you are around 280 or so.
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 09-28-2012, 11:31 PM   #8
Jgill1992's Avatar
Longtubes. Offroad pipes. Cams CAI and tune can put you 300+ at the wheels? Is it possible to get 350 without going FI?
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 09-28-2012, 11:42 PM   #9
Silversky545's Avatar
Here is what many many many speed shops have told me:
cai
Cmdp
Tb
Off rd mid
Long tubes
Cams
Port n Polish heads
pullies
Dyno tune
Will only get you around 360wrhp ... I don't quite understand it soooo my goal is to do all the above to see if they are correct...
They claim it's impossible to achieve 400wrhp w/o building a bottom end. I think w proper.supporting moddifications ie; aluminum driveshaft
Aluminum flywheel
Strong clutch
Uca, lca,
Pan hard bar, and brace
rear sway bar and links
Light radiator support
Tubular k member
Soft compound tires
And gears
Not that you need all that but if you did I truly don't see how you can't make 400wrhp n/a but even if you still don't have 400 w all that hp no longer matters that's high 11s... I would think
Silversky545 is offline   Reply With Quote
Old 10-01-2012, 07:09 PM   #10
2007pullinaway's Avatar
I have a little over 350 at the wheels with cams, headers, cai, x pipe and bassani axle backs and an aggressive dyno tune
2007pullinaway is offline   Reply With Quote
01:39 PM
