Help Needed In England - Idling Problem - Mustang Evolution
Old 04-08-2008, 02:21 AM   #1
Question Help Needed In England - Idling Problem
Hi there in the US
I have a 2005 Mustang GT. It has been in storage the last couple of months. I have reconnected the battery and all seemed well for a day or two. Now the car keeps intermittently stalling as it comes to a halt. The idling speed keeps dipping below 500 rpm...
Any ideas?
Cheers, Glen
glenheyes is offline   Reply With Quote
Old 04-10-2008, 07:38 PM   #2
05RedDevil's Avatar
Send a message via AIM to 05RedDevil
Re: Help Needed In England - Idling Problem
My guess would be that you have a dirty fuel filter. It is possible that sludge accumulated in your gas tank or fuel lines while the car sat for so long and then got sucked into the fuel filter when you started it up. This could explain why it runs fine when the gas (petrol for you english guys) is being pumped through (higher demand with foot on the throttle) but the restricted flow causes you hesitated acceleration and rough idle/ engine-cut out. You can change this out yourself if you are good with cars or you can have Jiffy Lube or your local Ford dealer change it for you
Some show. Some go.
462 rwhp/ 446 ft-lbs
05RedDevil is offline   Reply With Quote
Old 04-11-2008, 10:25 AM   #3
i dunno if the have jiffy lube in europe though.
http://i5.photobucket.com/albums/y200/mustangfan2003/MC.jpg?t=1196874772
Mustangfan2003 is offline   Reply With Quote
Old 04-11-2008, 10:28 AM   #4
05RedDevil's Avatar
Ok, maybe not JiffyLube but the equivalent of it. You know what I meant, you "wanker". I threw that in just for the English fellow.
Some show. Some go.
Old 04-15-2008, 08:13 AM   #5
Ok that makes sense. I will mention that when I take it to the garage next week...
Old 04-15-2008, 09:29 AM   #6
Is it a 5 speed and do you clutch it/put it in neutral coming to a stop? If so...try leaving it in gear, should solve your problem.
It's probably getting unsteady readings to the MAF with air bouncing around in your intake by shutting the throttle body quickly coming to a stop.
Old 04-15-2008, 09:46 AM   #7
Herbstang's Avatar
sounds like A fuel delivery problem is most likely causing the stalling. Check the fuel pressure regulator and the fuel pump.You might want to installed new spark plugs, cleaned maf sensor and clean iac valve w/ carb cleaner
Old 04-15-2008, 10:05 AM   #8
05RedDevil's Avatar
Once again, Herb, thanks for the positive reinforcement. I friggin' said it would probably be in the fuel system but I was starting simple without throwing too much his way.
Some show. Some go.
Old 04-15-2008, 11:46 AM   #9
Herbstang's Avatar
See I'm really not that big of a *******
Old 04-15-2008, 12:51 PM   #10
05RedDevil's Avatar
Let's not jump to conclusions now . . .
Some show. Some go.
Old 04-15-2008, 01:34 PM   #11
Herbstang's Avatar
Good point
Old 04-21-2008, 03:08 PM   #12
05RedDevil's Avatar
Glen, you get it checked out yet?
Some show. Some go.
Idling too low katie_ann 1996-2004 Mustang GT 9 09-02-2009 03:42 PM
Rough Idling greenmustang27 Pre-2005 V6 Mustang 2 05-14-2009 08:29 AM
problem, advice needed! Sublime782 Pre-2005 V6 Mustang 2 10-20-2008 07:21 AM
!Help! Engine Idling and Rev Issues 06v6stang Pre-2005 V6 Mustang 5 08-08-2008 07:12 AM
anyone from New England juicedgt02 Regional Mustang Discussion 6 01-30-2005 11:24 AM
01:17 PM
