Centerforce install issue HELP - Mustang Evolution
Old 10-10-2012, 09:27 AM   #1
So we just got everything bolted back up an bled the clutch, as far as we can tell. It goes in to gear ok 1-5 but it won't go in to reverse. Any ideas??
muscledom is offline   Reply With Quote
Old 10-10-2012, 09:43 AM   #2
Lorraine's driver
ab_mach1's Avatar
I'm not exactly sure how the hydraulic clutch connects to the clutch fork, but I think it just needs to be adjusted so its disengaging more when the clutch pedal is pushed all the way down.
Anybody else...
Instagram: @ab_mach1
Old 10-10-2012, 09:50 AM   #3
Anybody else...
It's an assembly in the bell housing. It's non adjustable.
Old 10-10-2012, 10:01 AM   #4
Lorraine's driver
ab_mach1's Avatar
We need some help.
Bump
Old 10-10-2012, 10:16 AM   #5
We need some help.
Bump
10 4 big homie. I'm hoping that the clutch wasn't completely bled. Hopefully there's just some air or foam still in the lines :/
Old 10-10-2012, 10:34 AM   #6
Lorraine's driver
ab_mach1's Avatar
I hope your right, and sounds logical too, as far as hydraulics go. A hydraulic clutch is like rocket science to me Never had one.
Old 10-10-2012, 10:39 AM   #7
Yea they make for a lighter clutch pedal but bleeding a centric TOB/slave cylinder is a ****ing whore. I guess you can use a vacuum bleeder but we don't have one........
Old 10-10-2012, 10:42 AM   #8
Lorraine's driver
ab_mach1's Avatar
That sucks, can you bleed them while everything is all put together? I guess the cool thing is that once your set, you don't have any adjustments you need to make, like cables.
Old 10-10-2012, 10:52 AM   #9
Well I guess it's all fixed. Ill find out what the problem was when I get back to the shop. But yea I believe so. The line coming off the assembly pokes out of the bell housing. So I think that's where you bleed it. That's true but it not really a big deal to adjust the cable. I've seen my buddy do it on his fox and it seemed pretty easy.
Old 10-10-2012, 10:57 AM   #10
Lorraine's driver
ab_mach1's Avatar
Cool man Glad you got it sorted out.
Old 10-10-2012, 12:19 PM   #11
Sirtat's Avatar
they way your "supposed" to do it is with a hand vacuum pump on the lid of your brake/clutch reservoir, pump is up to about 15 psi of vacuum hold for 20-30 seconds and the quickly pull the bung from the reservoir... many many many times :-/
I have also jacked up right behind the drivers front wheel and pumped the clutch until my leg was about to fall off and that bled the clutch too.
there is no bleeder screw and unless it was going to a remote location you couldn't reach it.
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 10-10-2012, 12:31 PM   #12
Pattyboy's Avatar
Try putting in first gear first then put in reverse in the the same motion
Pattyboy is offline   Reply With Quote
Old 10-10-2012, 12:49 PM   #13
It ended up being the rear adjustment but on my pro 5.0 shifter. I'm guessing the other guy must have bumped it when droppin the trans. Adjusted the bolt and she's all good
06:10 PM
