Shaking - Mustang Evolution
Old 10-12-2012, 07:26 PM   #1
Killastang's Avatar
Shaking
When I press on the brakes the steering wheel starts to shake. Has anyone else having or had this happen to them? How can I fix it? What should look at?
---------- Post added at 09:26 PM ---------- Previous post was at 09:25 PM ----------
The front tire are good and the brake pad are good to
Killastang is offline   Reply With Quote
Old 10-12-2012, 07:48 PM   #2
SSC182's Avatar
Your disc brake rotors are warped causing the pedal to pulsate either get new rotors or have them turned at a shop if they are thick enough to be cut.
SSC182 is offline   Reply With Quote
Old 10-12-2012, 07:52 PM   #3
Filibuster
+1
XXSTEVEO66 is offline   Reply With Quote
Old 10-12-2012, 08:30 PM   #4
Killastang's Avatar
If the rotors are in good shape what else could it be?
Old 10-12-2012, 09:04 PM   #5
Filibuster
From exactly what you explained your rotors ain't ”ok”
you said it only happens when you brake and you feel it in the steering wheel..that is textbook for warped rotors.
It's a cheap fix man no worries.
Old 10-12-2012, 09:07 PM   #6
Bleem@1's Avatar
Steve is right. Most shops charge 1.5 hours labor to turn rotors.
Bleem@1 is offline   Reply With Quote
Old 10-12-2012, 09:09 PM   #7
Jayjay's Avatar
Could it be your brakes are crystallize if they look good. Take your brake pats off and give them a quick sand down.
Jayjay is offline   Reply With Quote
Old 10-12-2012, 09:36 PM   #8
Caster Troy's Avatar
Region: Hawaii
It's your rotors for sure, don't resurface just by new ones. The only way they get like that is by the way you drive so resurfacing will just make them less heat resistant and warp even easier. Do you drive down hill a lot riding your brakes? That would be the cause.
Caster Troy is offline   Reply With Quote
Old 10-12-2012, 09:43 PM   #9
Region: Hawaii
Buy that is. Lol
Old 10-12-2012, 09:49 PM   #10
Filibuster
Yeah I'm not sure how much new rotors are for the sn197 but when I burned up pads and rotors I've always just bought new..rotors are cheap. Hell for a few extra $$ get some drilled/slotted rotors then your overheated warped rotors will be much less likely
Old 10-12-2012, 11:16 PM   #11
S197STANG's Avatar
+10...
---------- Post added at 12:16 AM ---------- Previous post was at 12:13 AM ----------
Also caused by braking and then hitting water puddles when raining, which causes warping from instant cool down! my mom has a bad thing with that, we have put already 2 sets on her car because of this lol. Ofcourse she still hasn't learned lol..just my 2 cents
---------- Post added at 12:16 AM ---------- Previous post was at 12:16 AM ----------
S197STANG is offline   Reply With Quote
Old 10-13-2012, 06:04 AM   #12
tc x 4's Avatar
SSC187 answered your question. Caused by your driving habits, fast driving fast stopping. If you want to drive it like that, upgrading the rotors to a performance set will help.
---------- Post added at 08:04 AM ---------- Previous post was at 08:03 AM ----------
Def change them or it will wear your front end out.
Old 10-13-2012, 06:30 AM   #13
Front rotors homie
muscledom is offline   Reply With Quote
Old 10-13-2012, 08:47 AM   #14
Loc: Austin,TX
Just pick up a decent set of slotted and dimpled aftermarkets. Great excuse for a upgrade/new mod!
Old 12-03-2012, 01:09 AM   #15
Jayjay's Avatar
Killastang did u ever fix your problem
10:43 PM
