Check engine light with new headers - Mustang Evolution
Old 10-17-2012, 01:16 AM   #1
Terminator's Avatar
So I installed new bbk longtube headers with short X pipe catted installed with the O2 sensor extensions AM sent me but I keep getting engine light on and when I check it with the handheld tuner I also got it says O2 sensor to lean figured it would of been fixed with the tunes BAMA sent me, anyone encountered this?
Terminator is offline   Reply With Quote
Old 10-17-2012, 05:52 AM   #2
Are you using the upstream sensors? And are they plugged in to the upstream plugs? When I did mine the connectors were backwards so we had to cut and splice the connectors so that they'd work with the extensions.
muscledom is offline   Reply With Quote
Old 10-17-2012, 07:54 AM   #3
AmericanMuscle.com
Sponsor
AMDanBailer's Avatar
^ Definitely give your sensors and extensions a once over and make sure they're in the right place. If everything looks good there, give my Bama team a call so they can go over your tune! Our tunes are good 99% of the time. Occasionally there are errors because we hand write each tune. I'm confident my Bama team will fix it quickly! Majority of the time, its Small human error when filing your tune information form or by a Bama Member!
Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764 and they'll get you squared away!
-Dan
Old 10-17-2012, 11:11 AM   #4
Caster Troy's Avatar
Region: Hawaii
I have the same set up on my 08, I get the code every once and a while. You can turn off your rear sensors with your tuner, not sure what effect it would have though. Since my code comes on only once and a while I just clear it when it does come on.
Caster Troy is offline   Reply With Quote
Old 10-17-2012, 11:33 AM   #5
Silversky545's Avatar
Call bama... tune issue
Silversky545 is offline   Reply With Quote
Old 10-17-2012, 12:01 PM   #6
AmericanMuscle.com
Sponsor
Caster Troy,
The same goes for you! Definitely give my Bama team a call and they can help you troubleshoot the CEL. Our Bama Performance tuning specialists are here in the building Monday-Friday from 9AM-5:30PM EST and Saturday 9AM-5:30PM EST. You can hit them up directly at 888.226.9764!
-Dan
Old 10-17-2012, 01:41 PM   #7
Gil_T2's Avatar
Make sure that the green is up stream and the blue are down stream, also DO NOT cut and splice the 02's, on the extensions you must cut the alignment tabs off to install them correctly.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 10-17-2012, 02:09 PM   #8
Terminator's Avatar
Yea ill do that after I have time to check wires and connectors
check engine
08:26 AM
