Spark Plugs - Mustang Evolution
Old 10-17-2012, 08:15 PM   #1
Jboogie's Avatar
Spark Plugs
What do u guys recommend for spark plug OEM or aftermarket?
Jboogie is offline   Reply With Quote
Old 10-17-2012, 08:25 PM   #2
Alonzo.dargan1's Avatar
Aftermarket plugs that are one-pieced designed, unlike the pos two-pieced designed ford put in.
Alonzo.dargan1 is offline   Reply With Quote
Old 10-17-2012, 08:34 PM   #3
Sirtat's Avatar
brisk plugs are the only thing I would ever run !! little pricey though but it is the best one piece IMO
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 10-17-2012, 08:43 PM   #4
Aggiesrok's Avatar
Do some research about removing the original plugs. They can break off. If you're careful they come. I got mine in one piece.
Old 10-18-2012, 05:36 PM   #5
Jboogie's Avatar
Anybody else use brisk plug?
Old 10-19-2012, 01:51 AM   #6
CZYFAST's Avatar
I use them in my supercharged 2010 GT and I won't ever use anything else!
IN SALEEN WE TRUST!!!
CZYFAST is offline   Reply With Quote
Old 10-19-2012, 06:19 AM   #7
Stang23's Avatar
I've used them.. There great plugs and wouldn't really use anything else
Full Exhaust, Full Bolt Ons, Full Suspension and Much More..
Custom Dyno Tune By B&D Racing
340 RWHP
325 RWTQ
Stang23 is offline   Reply With Quote
Old 10-19-2012, 08:53 AM   #8
Aggiesrok's Avatar
Do you see a difference without FI or nitrous? Just bolt ons and tune
Old 10-19-2012, 09:10 AM   #9
Stang23's Avatar
Not really. I mean you might feel a little bit of a difference and the car should run a little better that's about it
340 RWHP
325 RWTQ
Old 10-19-2012, 11:14 AM   #10
Jboogie's Avatar
Where can u order them domain?
---------- Post added at 01:14 PM ---------- Previous post was at 01:13 PM ----------
Where can u order them from?
Old 10-19-2012, 12:12 PM   #11
CZYFAST's Avatar
Brenspeed.com
Old 10-31-2012, 12:59 PM   #12
Jboogie's Avatar
What is the best way to take out 2 piece spark plugs?
Old 10-31-2012, 01:14 PM   #13
BenGT07's Avatar
Pay someone else to do it...
In the market for a Fox body...
SOLD: 2007 Performance white GT Premium.
Performance: Eibach lowering kit, SVT wheels, Steeda Camber Casters, Steeda short throw, FRPP 4.10's, Airraid CAI, BBK 62mm TB, Brenspeed Detroit Rockers, Pypes Longtubes with O/R H and Violators.
For fun: Window louvers, 15% tint, Raxiom tinted taillights, J&L Audio sub.
BenGT07 is offline   Reply With Quote
Old 10-31-2012, 03:05 PM   #14
tc x 4's Avatar
Penetrating oil and lots an lots of patience. If its your dd, buy the Lisle tool before hand just in case you brake one.
Old 10-31-2012, 03:11 PM   #15
Aggiesrok's Avatar
If Ford changes them and breaks them, they will charge a chunk to remove it. If you're careful you can do it. I changed mine with no breaks. The issue is when carbon builds up inside the head around the plug and allows the ceramic part to break. There are several links if you search here, I may have posted one a while back. The trick is to go slow, spray something that removes carbon around the plug, not too much and let it set for 15-20 minutes. Then loosen a 1/4 turn , tighten, loosen a little more, tighten , until it comes out. If you break one, they sell a kit online for around $80 to extract the broken piece. I think Ford charges around $200. Look it up, if you're careful it'll be fine. Ford is going to use an impact driver to remove it and may break one. I don't think you can buy the two piece POS plugs anymore.
Old 10-31-2012, 09:55 PM   #16
What is the Lisle tool and how do you know if you have two peice spark plugs?
jaymjohnson is offline   Reply With Quote
Old 10-31-2012, 10:03 PM   #17
2300turboford's Avatar
If they break they sell a tool to get them out it worked on my dads 07 f-150
Old 10-31-2012, 10:08 PM   #18
Lorraine's driver
ab_mach1's Avatar
Never heard of this company until this thread. I'm diggin it
Lisle Specialty Tools
Instagram: @ab_mach1
Old 10-31-2012, 10:43 PM   #19
Stang23's Avatar
Just saw this company recently as well. They look like they have some nice stuff
340 RWHP
325 RWTQ
Old 10-31-2012, 10:46 PM   #20
Lorraine's driver
ab_mach1's Avatar
Here's spark plug repair kits for Ford engines.
TIMESERT ® FORD SPECIFIC PROFESSIONAL SPARK PLUG THREAD REPAIR KITS
Old 11-05-2012, 11:46 AM   #21
Jboogie's Avatar
What r some good replacement spark plugs for a stock mustang with a few bolt ons?
Old 11-05-2012, 07:59 PM   #22
Stang23's Avatar
Ford racing or brisk plugs
340 RWHP
325 RWTQ
Old 11-05-2012, 10:16 PM   #23
Graham1992's Avatar
Ford racing 0 degree is a good cold plug
Graham1992 is offline   Reply With Quote
Old 11-12-2012, 05:54 PM   #24
soonerfan27's Avatar
With a factory setup, is there any benefit going with a 1 or 2 heat range colder plug?
soonerfan27 is offline   Reply With Quote
Old 11-12-2012, 06:12 PM   #25
Lorraine's driver
ab_mach1's Avatar
I think, only if you are experiencing detonation. Other than that, I'm not sure it would improve anything. Many go colder if you're forced induction.
Old 11-12-2012, 06:22 PM   #26
Sirtat's Avatar
you should buy colder plugs and a supercharger to make the plugs happy
IBLT IT
Old 11-12-2012, 06:23 PM   #27
Lorraine's driver
ab_mach1's Avatar
Yes!!!
Old 11-12-2012, 06:51 PM   #28
You foot the bill and I'll be all over that. Otherwise, it'll have to stay stock for awhile.
12:01 AM
