Possible Death Wobble? 07 GT - Mustang Evolution
Old 10-27-2012, 01:09 PM   #1
I was driving on the freeway today, twice during one of those long sweeping turns it seemed that the front tires started wobbling kinda hard and my steering wheel would shake and you could hear a rapid thump noise from the front. It would only last a few seconds and then go back to normal.
I looked up a few videos online and its not a violent shake that rattles the whole car.
Could this the beginning stages of the infamous death wobble or could this just be I need to balance and rotate my tires?
Any suggestions would be appreciated. Thanks.
Matt07 is offline   Reply With Quote
Old 10-27-2012, 01:15 PM   #2
Pete Jones
90mustangLX's Avatar
Send a message via ICQ to 90mustangLX Send a message via AIM to 90mustangLX
Start by checking your lug nuts, make sure they are tight and still all there. Then I would check the ball joints and tie rods.
90 LX hatchback
(sold but not forgotten)
89 LX Notchback
No motor/trans (for now)
90mustangLX is offline   Reply With Quote
Old 10-27-2012, 01:43 PM   #3
Loc: Austin,TX
Do you have aftermarket wheels?
Old 10-27-2012, 01:47 PM   #4
Yeah, they're Michelin all season tires
Old 10-27-2012, 01:56 PM   #5
It's not me, it's you.
primer2tone's Avatar
Yeah, like 90LX said, check your lugs.
NOW!!!!!!!
And if they are fine, go get your wheel balance checked.
Old 10-27-2012, 02:17 PM   #6
@ DDTCM, sorry I'm at work and I read your post too quickly before responding. The tires are about 2 years old, but they're on the original 17'factory wheels.
Old 10-27-2012, 02:30 PM   #7
Loc: Austin,TX
It's not what I'm thinking if you have factory wheels then.
Old 10-27-2012, 02:42 PM   #8
Caster Troy's Avatar
Region: Hawaii
Check the lug nuts first and make sure they are properly torqued. Next, feel your tires and look for any bulges in the tread, you may have a separated tire. If the shaking happens between 50-60 MPH and smooths out when you speed up its probably your tire balance.
Hope this helps, good luck.
Caster Troy is offline   Reply With Quote
Old 10-27-2012, 02:44 PM   #9
Lugs, thrown a wheel weight, wheel bearing, tie rod ends, ball joints. Jack her up and start wiggling ****. Check your psi too
muscledom is offline   Reply With Quote
Old 10-27-2012, 02:56 PM   #10
You may have some belts slipping or busted in the tire(s).
Old 10-27-2012, 03:10 PM   #11
@ Caster Troy, yeah that's been happening too. A little vibration between 50-65mph then stops when I hit 70.
Old 10-27-2012, 05:33 PM   #12
Pattyboy's Avatar
Don't risk it I would get new tires IMO !!!!!!!!!!! .
Pattyboy is offline   Reply With Quote
02:46 AM
