Rear Brake Caliper Issue - Mustang Evolution
Old 10-29-2012, 12:35 PM   #1
I am having an issue with my rear brake caliper. I can not install new pads due to the caliper not going in when i turn and push. I am even using the new specific tool, one of the shop guys tried as well...gave me a awkward look and just walked away. Anything?
jaymjohnson is offline   Reply With Quote
Old 10-29-2012, 12:44 PM   #2
Blogger
99ford's Avatar
That's not cool
Hmm so the rear piston won't release back into the caliper?
Have you tried some lubrication? is it rusted?
I'll help you bump this up!
Old 10-29-2012, 12:56 PM   #3
Blogger
99ford's Avatar
Did you take the cap off the reservoir under the hood?
Old 10-29-2012, 01:04 PM   #4
Blogger
99ford's Avatar
Also are both sides giving you trouble?
Old 10-29-2012, 01:32 PM   #5
I tried taking the cap off of the reservoir in the engine compartment. and yes both sides are giving me issues! i was able to replace the front brakes but not the rear so far.
Old 10-29-2012, 03:25 PM   #6
Alonzo.dargan1's Avatar
The rear caliper brake pistons on our stangs are twist in pistons. You can rent the special tool to rotate the piston at autozone for $60.00. Just tell them you need brake piston tool kit.
Alonzo.dargan1 is offline   Reply With Quote
Old 10-29-2012, 05:51 PM   #7
Blogger
99ford's Avatar
I think he is using that.. He said special tool so I am assuming he's using that. If not then that will solve your problem.. But i think you are.
Hmm are turning it clockwise? And have you tried counter clockwise?
I'd try spraying them down with some cleaner real good. Cover and smother.. Try it again really give it some force..
If that doesn't work, from what I've read you have 2 options.
A: Open the bleeder valve and pray that works.
Or
B. Replace the calipers
Old 10-29-2012, 11:23 PM   #8
Or
Yes, i am using the brake tool.
I will try this as soon as i can. If i end up having to replace the calipers i will probably upgrade all of my brakes at the same time. ughhhhh
Old 10-30-2012, 11:08 AM   #9
Gil_T2's Avatar
I can not remember if you need to release the E-brake cable, before you screw it in. On some cars the piston will not screw in till you do that. If you tryed to press it in before you got the tool, you may have broken them, and will need to replace them with rebuilts. opening the bleaders will NOT help.
BBK LT's, Catted Xpipe, Sniper tune, UDP's GT500 TB, Ford Racing CAI, CM delete, 4.10, TR6060, 1 piece DS
Gil_T2 is offline   Reply With Quote
Old 10-31-2012, 11:52 PM   #10
I remember the last time i tried i made sure i never set the e brake because i had the issue with my jeep. I will not be back in the states for a little while, so i will not be able to try again for a little bit.
---------- Post added at 11:52 PM ---------- Previous post was at 11:49 PM ----------
Now that i think about it, the E-Brake would make really good sense since i am having issues with both sides.
Old 11-01-2012, 06:08 AM   #11
Blogger
99ford's Avatar
You don't have it engaged do you?
Old 11-01-2012, 06:16 AM   #12
Blogger
99ford's Avatar
Looked in the book it says you shouldn't have to release the cable but make sure it is disengaged. But you may want to give it a shot before replacing the calipers.
Old 11-05-2012, 10:33 PM   #13
Graham1992's Avatar
I had the same problems and I went ahead and changed the calipers. You won't regret it!
Graham1992 is offline   Reply With Quote
04:46 AM
