engine problem after new clutch - Mustang Evolution
Old 10-31-2012, 01:43 AM   #1
help
I had a new clutch put in and the flywheel turned in my 2005 Mustang GT. Now it's running like a bag of hammers. While searching the threads I found TSB 21474 crank sensor relearn. The car ran fine before taking it in. Now I have a code for misfire cylinder number 4. I also have a very bad rattle at 1400 RPM under load in 1st to 4th but not in 5th that I can hear. The sound seems to be coming from cylinder number 4 right rear of engine. It sounds to me like its running the wrong octane or a valve rattle. This problem did not exist before I took it in for the new clutch.
Running 94 octane so I'm sure it's not an octane problem.
Would the crank position sensor being out of whack make a cylinder rattle?
I'm looking for an opinion regarding what may be causing the noises.
I will be taking it into FORD next week. I can't afford to get the crank relearn right now so any help would be appreciated.
Frankndeath is offline   Reply With Quote
Old 10-31-2012, 05:51 AM   #2
Make sure there aren't any damaged wires. When i did my last clutch several months ago we caught a wire loom in between the bell housing. Car ran like a fat piece of **** and even went in to limp mode.
muscledom is offline   Reply With Quote
Old 11-12-2012, 07:00 PM   #3
Sirtat's Avatar
any updates ?
IBLT IT
2005 Promar Performance forged long block
Kenne Bell 2.8L LC mammoth supercherger
and and and I DRIVE IT LIKE I STOLE IT !!!!
http://www.youtube.com/watch?v=_K_QJ...ure=plcp<br />http://www.youtube.com/watch?v=NWfvYVYlfio&feature=plcp
Sirtat is offline   Reply With Quote
Old 11-12-2012, 08:29 PM   #4
tc x 4's Avatar
Idk about Ford cars, but on the trucks missfire on #4 can be a loose 02 sensor wire. Maybe it got bumped.
01:51 PM
