need someone to listen to their car idle - Mustang Evolution
Go Back   Mustang Evolution > 1979-2014 Mustang GT > 2005-2009 Mustang GT
Closed Thread
Old 04-25-2008, 10:49 AM   #1
shelbygt07 is unknown around these parts
i went to the dealer for possible cam phaser replacement but that wasnt done cause they believe the noise i hear is caused by my oil filter, i got back from the dealer and they changed the oil and stated the fram oil filter doesnt have a vent that allows for the oil to reach the top of the valve train due to lack of pressure build up, which could equal noise and knocks from decrease oil saturation. the mechanic was pretty persistant about needing to use the motorcraft oil filters.(with recent research from other sites i found that infact fram oil filters can cause engine noise) they told me if i have anymore problems with noise to bring it back in a month and theyll do a complete tear down. i played stupid and asked can i buy the oil filters here just to see if he was just trying to get me to come to them and buy em and have my oil changed and he said you can get them at walmart to save some money. anyways the slight knock is gone at idle but i do still hear a rhythmic swishing noise at idle when standing and having my head next to the grill on the car.do any of you have the same sound. can you check on your cars.
shelbygt07 is offline
Old 04-26-2008, 04:31 AM   #2
stang_gang's Avatar
stang_gang is unknown around these parts
Re: need someone to listen to their car idle
my 07 gt is noisy to but if you have the shelby gt the swooshing sound could very posible be the factory cold air intake they are alot noiser then the factory setup.
Mustangs are not anobsession they are a way of LIFE!!!
stang_gang is offline
Old 04-26-2008, 03:24 PM   #3
Terminator Owner
SpectorV is just getting started.
the mechanic is correct, only two filters on the market have a drain back that the ford engine needs. the oem ford and the wix filters, dont use anything other than those. the oem ford filter is actually one of the best oil filters on the market for the money.
SpectorV is offline
Old 04-30-2008, 06:07 PM   #4
could i have damaged my engine at all. it seems to be okay i guess.
Old 05-01-2008, 05:09 AM   #5
stang_gang's Avatar
the mechanic is correct, only to filters on the market have a drain back that the ford engine needs. the oem ford and the wix filters, dont use anything other than those. the oem ford filter is actually one of the best oil filters on the market for the money.
does K&N not have the drain back valve? the box says it does if aplicable and that what i use on my 07. if not maybe thats why mine is noisy too.
Old 05-01-2008, 07:06 AM   #6
Terminator Owner
I am just going by what ive heard many times that to use oem ford (one of the best anyway on the market) or wix (same thing)
SpectorV is offline
Closed Thread
When the wife doesn't listen. at7311 The Bar 8 10-26-2008 09:13 PM
What do you listen to Seph The Bar 8 05-03-2007 08:46 AM
My car seems to idle rellay rough, and miss badly johnpittbull 1979-1995 Mustang GT 21 07-04-2006 09:06 AM
does anyone here listen to launchcast? chips The Bar 3 12-20-2004 09:12 PM
Code reading? and Car that idle Lobes and stalls stick0014 Pre-2005 V6 Mustang 4 09-03-2004 08:33 PM
09:46 PM
