Starting in the cold issues - Mustang Evolution
Old 11-09-2012, 09:16 AM   #1
Jgill1992's Avatar
Ok the last few days its been down to LOW 30's high 20's in the morning when I leave for work.
The first couple times I start it it chokes and dies. Than I start it 3-4 times it'll run fine but I have to give it a little gas to get it going than it runs perfect. It was warm today 45 and it started and ran awesome
---------- Post added at 10:16 AM ---------- Previous post was at 10:15 AM ----------
I'm just worried about when it gets really cold this winter it might not start at all...
2015 Mustang GT Premium. No mods yet.
Jgill1992 is offline   Reply With Quote
Old 11-09-2012, 09:17 AM   #2
my 01 had an issue where when cold it would not idle, just die. The issue is the idle bypass valve (IAC) its usually near the throttle body, a cylinder shaped thing. This may not be your issue but it could be~ when its cold they can stick (carbon deposits etc)
Old 11-09-2012, 09:18 AM   #3
Jgill1992's Avatar
Ill check it out thanks for the fast response! I really don't want to have to fix my silvarado and drive it durring the winter... Damn Chevys
Old 11-09-2012, 09:28 AM   #4
some say you can pop off the IAC and clean it good to fix it, not sure though
Old 11-09-2012, 03:32 PM   #5
stemar's Avatar
you could also check the coolent temp sensor my last car had 2 coolent sensors 1 for the gauge and one that sent a signal to the ecu if your coolent sensor is going bad it will send an incorrect signal to the ecu witch inturn will give you hard start-up issues on cold days
Pypes shorties, BBK catted X, Flowmaster Pro's, K&N CAI, FRPP- P springs, Steeda UCA, J&M Panhard bar, Hurst Comp plus, FR500 Wheels W/NITTO's , SCT SF3 W/BAMA 93 Race tune, Pioneer TS-D6802R speakers, chin spoiler, Eleanor style grill, GT500 rear spoiler
stemar is offline   Reply With Quote
Old 11-09-2012, 06:17 PM   #6
tc x 4's Avatar
Make sure battery cables are cleaned and greased.
Old 11-09-2012, 07:13 PM   #7
Jgill1992's Avatar
Battery cables are clean battery is new I clean the engine more than I clean the rest of the car lol. Ill be messing around with if. It's hard to troubleshoot issues that only happen on freezing days when it's nice out...
Old 11-10-2012, 06:37 AM   #8
jdavis96gt's Avatar
Region: West Virgina
Did it make your check engine light come on?
Old 11-10-2012, 07:22 AM   #9
Jgill1992's Avatar
Nope nothing!
Old 11-12-2012, 01:10 PM   #10
I am having the same issue with my 96 GT. Only when cold or raining. If I add a bottle of heet to the tank and keep turn the key off and on a few times. Then try to start on the 4th or 5th time it will keep running. Temps above 50 no problems with starting. Engine light is on and the auto parts store said it was the code for fuel tank pressure. Is it possible for starting issue to be the IAC also.
Rick
kc9krb is offline   Reply With Quote
Old 11-12-2012, 01:17 PM   #11
jdavis96gt's Avatar
Rick
Hard to start in rain could be plug wires or coil. They can actually pull moisture in. Then being wet would make it hard to start. Then when it does start it dries itself. Something to check/read about.
Old 11-12-2012, 01:17 PM   #12
tc x 4's Avatar
Rick
Your prob sounds like a weak fuel pump or clogged fuel filter.
Old 11-12-2012, 01:29 PM   #13
Jgill1992's Avatar
It has a new fuel filter. Can the pump really go out a 55k miles? I guess anything is possible. It ONLY does it when it's below 35 tho
Old 11-12-2012, 02:06 PM   #14
tc x 4's Avatar
Sorry, I was referring to KC 9 , but it can go out with 1 mile on it.
Old 11-12-2012, 03:33 PM   #15
Jgill1992's Avatar
Damn electronics haha
05:12 PM
